Coolant cooling too much after change?? - Ford Powerstroke Diesel Forum
post #1 of 42 Old 01-03-2014, 09:50 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
A few weeks ago i had my oil cooler orings leaking so i decided to do a coolant flush as the same time while i was in there anyway. I also replaced the t-stat(Stant 205) and housing. I totally flushed the system and refilled with fleet charge concentrate and topped off with distilled water just like your supposed to.
Well since then my temps wont even get into the "normal" part of the dash gauge and before it would at least get into the "normal" part and my heat would toast you out and now it barely is enough to thaw out your fingers after a 30 min drive(50/50 interstate/city).
I know, i know, the dash gauge is just a dummy light blah blah blah but if you compare the before and after on top of the non existant heat theres obviously something up. I pulled the t-stat and heated it up and it opens and closes just like it should and while i had it out i drilled a tiny hole to help evacuate the trapped air and still after a few weeks it still doesnt get up to proper temps. What gives??
Does the new coolant cool more efficiently than the probably original tired green coolant that was in it? Or is the winter just taking that much toll on it. Guys on here swear up and down that a winter front is unnecessary but im thinking of trying it just to see
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 42 Old 01-03-2014, 09:54 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
Maybe the heater core isn't working properly
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #3 of 42 Old 01-03-2014, 09:56 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
How would the heater core affect operating temps?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 42 Old 01-03-2014, 10:00 AM
Quoted: 3 Post(s)
It wouldn't but I was spitballin. Try blocking off the grill with some cardboard to see if that helps
post #5 of 42 Old 01-03-2014, 10:02 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well i have a winter front i made this summer, havent tried it yet but ill tell you that if i really get on it going up a steep hill i can get the temp to come up and the heat is nice and toasty
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 42 Old 01-03-2014, 10:06 AM
Quoted: 3 Post(s)
I'm gonna guess the 205 degree thermostat is the root cause.. Try your winter front and get back to us
post #7 of 42 Old 01-03-2014, 10:10 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Fan clutch isn't staying engaged is it?
dhanna6powerstroke is offline
post #8 of 42 Old 01-03-2014, 10:22 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
That would make the truck run hotter if anything.
Well now what does that mean because in every vehicle ive ever owned or seen the fan runs 100% of the time but after reading on threads here it sounds like that isnt right? Is there a difference between spinning and being engaged?
Also why would it start just right after flushing? Its a mechanical clutch so its not like i coulda messed with the wiring while in there
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 42 Old 01-03-2014, 11:15 AM
Mod Newbie
Quoted: 20 Post(s)
They all will spin some but doesn't mean the clutch is engaged. Shut the truck off and grab the fan and try to rotate it. It should have some resistance but should turn. If you can't turn it with minimal effort then your clutch may be your issue.
post #10 of 42 Old 01-03-2014, 11:20 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
I am able to spin the fan fairly easy, as in a light to medium push but its not like im having to put any umph into it for it to spin.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
