PCM cross refference - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-02-2014, 11:48 AM Thread Starter
derkracer's Avatar
Hey guys, I am new to this forum but not to forums in general. I have a 96 F250 Powerstroke 4x4 auto E40d. My PCM has gone out on me and I am having a really hard time finding a replacement. It is DPC-202 F6TF-12A650-AYE. My question is what other PCMs will work for my truck. Thanks in advance.
derkracer is offline
post #2 of 5 Old 01-02-2014, 11:59 AM
Quoted: 50 Post(s)
It's the four-character (XXX9) PCM code on the sticker behind the parking brake assembly that counts. This: PCM Codes - 1994-1997 Power Stroke FAQ might help.
madpogue is online now
post #3 of 5 Old 01-02-2014, 12:23 PM Thread Starter
derkracer's Avatar
Thanks. I already pulled the pcm out, is the sitcker on the pcm or in the truck behind the parking brake assembly?
post #4 of 5 Old 01-02-2014, 12:26 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
on the pcm, Should be something like TEE5 or SOD4 or ALF6 or BEG5
Trucks and parts............
kanuck15 is offline
post #5 of 5 Old 01-02-2014, 05:51 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Check with RockAuto as they many times have them for a decent price (see this link for Standard Motor Products EM1412). If yours hasn't been reflashed at some point, it should be an NAW4 code (based on the F6TF-AYE. The main thing is you need another DPC-202 (Federal trucks with an E4OD tranny) PCM with a NAW4 or later code (such as NAW5 or NAW6) even earlier codes could be reflashed to the latest Federal Auto code. Here's a good reference for you: PCM Codes
Cheers!
Patrick Feeley is offline
