Help with my F350 build - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-01-2014, 08:30 AM Thread Starter
DieselNic's Avatar
Smile Help with my F350 build
I own a 97 Ford F250 7.3l 4x4 5spd 4:10 gears 290,000km on it. There has been a ton of work put into this truck both when I owned it and when the previous owner owned it. Right now it is an F250 4x4 Dually with 3inch spacers on the back to make the regular single wheel axle as wide as the dually rear end.
I'm planing on lifting it and putting 35s on it, Dana 60 conversion (have the d60) and dually rear end (also have the dually rear end), Building a reverse shackle kit and Rear end trac bar and firestone rite ride air bags.
So Basically I'm wondering how much should I lift it to get the 35s to fit? Right now it has the f250 front springs with leveling kit from previous owner. The back I think I will do a block lift. Keep in mind I have the aluminum side steps all the way around. Just curious as to everyone thoughts on this. I was thinking I might go with 6inch lift. I don't have the the F350 front drive shaft, I'm wondering if I have cut the F250 one. But also if with that lift would that be to much of an angle for it?
I have the d60 in my shop. I plan to do a complete rebuild of it, same with dually rear end. Right now the d60 has 3.55s in it. I plan to do a gear swap to it. Wondering if anyone has any pointers for me on this as well?
I plan to build a reverse shackle kit and was also wondering if anyone has done this before and if they would have any pictures to share? And also for a rear end trac bar setup. I work at a place with access to almost everything I need, Plasma cutter, torches. All help appreciated. Thanks.
1997 4x4 Ford F250 7.3L Powerstroke
Dually conversion
Dana 60 conversion
35 lights added
Exhaust Brake
West Coast heated mirrors
Clear head lights
5 inch stacks
3 inch down pipe
33s with 3 inch spacer in the duals
Napa intake
Solid flywheel
DieselNic is offline
post #2 of 6 Old 01-01-2014, 10:54 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
You can fit 35s with a stock 1 ton suspension and you can add a double cardigan joint to the end of the shaft and you will be good
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #3 of 6 Old 01-01-2014, 11:15 AM Thread Starter
DieselNic's Avatar
O.k Thanks. Can you buy that joint brand new? I'm going to try to buy a used 35 if I can get one for dirt cheap just to be sure.
Dually conversion
Dana 60 conversion
35 lights added
Exhaust Brake
Clear head lights
5 inch stacks
3 inch down pipe
Napa intake
Solid flywheel
post #4 of 6 Old 01-01-2014, 12:47 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
To COMFORTABLY fit 35s, you will want 3" of lift from a F350s stock height
Here is your truck, but a crew cab.
It was a SRW Crewcab Short Bed f250 that I made into a F350 using Dually front and rear axles. It has a PMF 2.25" RSK w V code front SD springs
and B code rear SD springs w 5" blocks
2" spacer between rear rims to clear the sidewalls
315/75/16(35x12) tires on 16x6 wheels
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 6 Old 01-01-2014, 01:09 PM Thread Starter
DieselNic's Avatar
Wow thats one nice truck! Thank you very much that helps a lot. I could easily fit 35s no problem right now if I did not have the side steps.
Dually conversion
Dana 60 conversion
35 lights added
Exhaust Brake
Clear head lights
5 inch stacks
3 inch down pipe
Napa intake
Solid flywheel
post #6 of 6 Old 01-01-2014, 04:34 PM
Quoted: 4 Post(s)
Mine rub my mud flaps
Also, you better plan on cutting and or shimming you bumper if you think of running 35s at stock f350 height
