Fuel line connector at rear of head - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-31-2013, 03:50 PM Thread Starter
This fitting is on the back of the driver side head where the fuel line connects.
Is this an OEM fitting?
It doesn't match the straight fitting on the opposite head.
clint_ives is offline
post #2 of 17 Old 12-31-2013, 07:23 PM
Quoted: 770 Post(s)
Definitely not OEM.
Corey@CNCFAB is offline
post #3 of 17 Old 12-31-2013, 07:58 PM
theforeman57's Avatar
Quoted: 4 Post(s)
I cant tell if That is gease or paint, and I cant remember if mine was just a single fitting, or was two fittings. I am leaning towards saying that yes, that is OEM.
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #4 of 17 Old 12-31-2013, 08:49 PM Thread Starter
This fitting has no orings or the 1/4" rubber seal that's on the opposite fitting?
This is what's throwing me off. I've ordered the 1/4" seal for both fittings, but not sure where I should add it on this side, as the fitting in the picture is 2 pieces.
post #5 of 17 Old 01-01-2014, 01:47 AM
Quoted: 770 Post(s)
The closer I look, I think it is OEM. The rubber seal in the pic looks like its hardened and is stuck on the fitting side.
In the pic the tubing is still in the fitting?? If so, then yes, it is OEM. Threw me a bit because the SD's dont have double 45* fittings. They are just straight and the the tubing is bent accordingly.
post #6 of 17 Old 01-01-2014, 07:35 AM
m j
not an oem
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #7 of 17 Old 01-01-2014, 07:59 AM
Micko's Avatar
Quoted: 4 Post(s)
Here's a picture from my 97. The fitting is not screwed in all the way.
Micko is offline
post #8 of 17 Old 01-01-2014, 08:09 AM
m j
the OEM one cannot be removed or installed without pulling the turbo
so someone used parts that could be removed
run what is there
m j is offline
post #9 of 17 Old 01-01-2014, 08:16 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
That is a 94.5 fitting that came stock. The early years had a two piece fitting so it could be removed with the up pipe still in there.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #10 of 17 Old 01-01-2014, 09:01 AM
m j
interesting info. they should have kept that design
m j is offline
