insultated block heater ??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-31-2013, 02:33 PM Thread Starter
Anyone ever considered or tried some sort of insulation around or near the block heater ?
I'm sure there are various factors to consider and/or that might rule this out. Tried searching, came up empty. Toughts/?
block heater insulate insulated insulation winter cold start freezing below zero 0 negative temp temperature
normal is offline
post #2 of 5 Old 12-31-2013, 03:18 PM
CSIPSD's Avatar
WTF for? It heats the coolant...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 5 Old 12-31-2013, 03:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
sounds not so good
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 01-03-2014, 02:46 PM Thread Starter
thanks for dropping the f-bomb.
the heaters were installed by ford good reason, not interested in debating use/need for the heaters
my post/question was whether anyone had considered doing some sort of insulating to make the them more efficient (thus requiring less time plugged in to achieve same result)
normal is offline
post #5 of 5 Old 01-03-2014, 04:56 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
3 hours is all you need. The cast black does a pretty good job of insulating the coolant
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
