powerstroke swap questions - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-29-2013, 05:26 PM Thread Starter
NorcalPSD925's Avatar
im doing the wiring on my 67 f250/powerstroke conversion and i have a few questions.
can i use a 96 cali PCM (MIF4) with a 97 federal motor? havent pulled valve cover yet but pretty sure it has single shots
what is really needed to run this motor?
i have all the wiring, sensors, PCM, IDM, throttle petal, gauges, dash wiring, etc.
anyone have diagrams for the wiring?
anything else i should know while doing this swap?
96 7.3L, RCSB, Race truck
Only regular cab short bed OBS in Nor Cal!
NorcalPSD925 is offline
post #2 of 5 Old 12-29-2013, 05:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You can run the Cali harness on a fed motor if you re pin it and use a federal PCM as well
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 12-30-2013, 05:41 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
You can run a splitshot ECM with single shot injectors?
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 5 Old 12-30-2013, 05:43 PM Thread Starter
thats what im asking..
post #5 of 5 Old 12-30-2013, 05:44 PM
Quoted: 4 Post(s)
I didn't think it was possible unless you got the ECM reflashed
