Dash lights - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 Old 12-28-2013, 01:06 PM Thread Starter
deezelfromRofo's Avatar
Dash lights
My left side of my dash is dark. What do I disconnect from bezel above steering wheel? Any helpful hints?
97 ford f250 HD supercab xlt longbed
banks intercooler
banks power pack
285 75 16's
3" dp
DIY tymar intake 6637
stancor 586-902
B&W tow n stow
triple pillar gauges:
Banks Dynafact boost gauge
Banks Dynafact egt gauge
ISS Pro trans temp gauge
Hayden 32k transcooler
kittyless and unmuffled
deezelfromRofo is offline
post #2 of 12 Old 12-28-2013, 01:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Are you asking how to fix it?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 12 Old 12-29-2013, 06:53 AM Thread Starter
Yes please I would like to know how
banks intercooler
banks power pack
285 75 16's
3" dp
stancor 586-902
B&W tow n stow
post #4 of 12 Old 12-29-2013, 08:22 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Remove dash overlay by popping off the trim pieces you will see a bolt on each side, remove headlight knob, when you pull it out be carefull to remove the fuel switch the tabs can be brittle and break, and disconnect the wts harness
The gauge cluster is held in by a couple screws I believe 4 or 6, and their are 3 harnesses that plug in the back as well (again they are brittle) the black turn knobs hold the light bulbs in just a 1/4 turn to a 1/2 turn they come rite out, I believe the bulb size is type 194, good luck
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
The Following User Says Thank You to 351fifty For This Useful Post:
94Powerstroke_97303 (12-29-2013)
post #5 of 12 Old 12-29-2013, 07:35 PM
94Powerstroke_97303's Avatar
Can you please post any issues or if everything was successful?
Thanks!
94Powerstroke_97303 is offline
post #6 of 12 Old 12-30-2013, 02:46 AM
Ranzan's Avatar
Quoted: 23 Post(s)
^^^^ what Fifty said
common to happen
I have had to pull my dash a couple of times for burnt bulbs
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #7 of 12 Old 12-30-2013, 05:20 AM Thread Starter
How do I get the damn headlight knob off?
banks intercooler
banks power pack
285 75 16's
3" dp
stancor 586-902
B&W tow n stow
post #8 of 12 Old 12-30-2013, 07:54 AM
clatterindiesel's Avatar
You need a tiny flathead screwdriver, or a dental pick. There is a metal tab you need to lift up on the inside of knob itself. Twist knob until you see a gap in the knob. Insert tool of choice in there and gently pry up the tab while pulling on knob. Be advised you need to turn lights on to find the gap I speak of, so don't forget to turn lights off when you get knob off.
I live close to ocala and surrounding areas, so if anyone ever needs a hand with their truck....get a hold of me.
clatterindiesel is offline
post #9 of 12 Old 02-02-2014, 10:20 AM Thread Starter
What a pain in the balls. Replaced all 16 bulbs right wrong or indifferent. Not playing that game again.
banks intercooler
banks power pack
285 75 16's
3" dp
stancor 586-902
B&W tow n stow
post #10 of 12 Old 02-02-2014, 12:07 PM
It wasn't that bad... Wish I didn't break my bezel tabs though....
'94 F350 7.3l PowerStroke Turbo Diesel 5sp
CrewCab 4x4
A lot of new OEM parts, add a leaf in the front.
