Pulled my motor today. What to re-seal? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-27-2013, 05:54 PM Thread Starter
AddictedOffroad's Avatar
I pulled my motor today. Am I missing anything else I should do while its out?
My list of "To Do" things while its out.
1. Oil Cooler o-rings.
2. ICP o-ring
3. Oil pan gasket
4. IPR O-rings
5. Rear main seal
I also bought the oil rail end plug o-rings, oil rail o-rings, CCV o-rings, and turbo pedestal o-rings as well as a turbo rebuild kit since I am installing a Bean's 1.0 exhaust housing, and WW2 on the turbo.
I've already rebuilt the fuel bowl. I have one year old Rosewood Stage 1's in it and one year old glow plugs(ZD-11s). I also did the valve cover gaskets and wiring harnesses under them. HPOP is a T-500 and installed about 6mo ago.
I had oil leaks in the valley from the ICP o-ring, and the oil cooler was leaking as I didn't use the good viton seals last time. Oil pan gasket has always leaked since I got the truck as well.
Anything else you would do with the motor out of the truck?
On a side note. Even after doing the UVCH last year and all glow plugs + relay, this thing smokes like a freight train when cold. Its eye burning smoke and basically all diesel. Truck has no blow-by either. It always starts, but lopes badly for several seconds before evening out. Injectors were rebuilt by Rosewood last year. Any thoughts? Maybe bad up stream wiring? The full engine harness is saturated in oil, so I plan to go through it as well and clean everything and re-wrap it all.
Oh, and even when plugged in, I will get a slight blue/white haze from the tailpipe when its below freezing here in CO. None of my other 7.3s have ever smoked after being plugged in, and none of them ever came close to the smoke this will truck will throw un-plugged.
Scotty
1999.5 F350 DRW, CC, LB, A/T, 7.3L. Bank Exhaust brake, 4" Exhaust, BD power Thruster II turbo, PHP Hydra
AddictedOffroad is online now
post #2 of 3 Old 12-28-2013, 03:53 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
2. ICP o-ring
3. Oil pan gasket
4. IPR O-rings
5. Rear main seal
the oring on the LPOP and the dipstick. other than that you got everything i was going to suggest (oil rails plugs, pedistal, orings, oil pan) by the way the oil pan has no "gasket" just an RTV tyoe sealant. i have heard that it is smart to use the gray that was used originally i think it is wacker t 442
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 3 Old 12-28-2013, 07:07 PM
Micko's Avatar
Quoted: 4 Post(s)
How about the up pipe donuts? Also, I replaced the injector o rings in my engine and now experience similar smoking issue as you describe. I may revisit them before I sufocate
Micko is offline
