Poly v. Rubber Body Bushings??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-15-2008, 12:16 PM Thread Starter
Quoted: 6 Post(s)
Send a message via AIM to PSDfreak
Its time to do the body-frame bushings on the truck...The OEM rubber is pretty trashed and the cab is moving around quite a bit while driving. I am temped to go the poly route so I only have to do it once and its done! However, I am a little leary because I am afraid that it may negatively affect the ride. I did the front suspension with poly bushings which was fine, however when I did the rear suspension bushings with poly the ride suffered greatly (a lot of small jarring bumps while driving) and I ended up pulling them back out and replacing with rubber. Wondering if anyone could share their experiences with replacing the body bushings with poly and what you thought....
'97 F-250 PSD, 4x4, ZF-5...Few Doo Dads
Tuned by TW -
-- SOLD
'09 F-250 6.4L, FX4, CCLB, 4" Pure Performance 4-Link Suspension Lift, 325/60/20 Goodyear Duratracs -- SOLD
'14 F-350 6.7L, Lariat, CCLB
RED 31
PSDfreak is offline
post #2 of 6 Old 09-15-2008, 02:07 PM
POWERSMOKIN's Avatar
no experiences, but based upon your experiences, id go with rubber.
~Mike Lewis
1996 F-350 CC LB PSD
Beans Stage 1's - 6637 Intake - SD HPOP - 5" Exhaust
E4OD w/ Shift Kit - Sky MFG Reverse Shackle
265,000MI
POWERSMOKIN is offline
post #3 of 6 Old 09-15-2008, 02:19 PM
DunesRunner08's Avatar
you always want to go with poly......it won't rot or deteriorate like rubber will..... your ride will not be affected.... I just replaced every bushing on the bronco with Energy Suspensions and/or Daystar and the ride got better
Beware!!!! The King Has Returned
DunesRunner08 is offline
post #4 of 6 Old 09-15-2008, 02:22 PM
Broncoguy's Avatar
Bushings
I have poly in my 92 and love it! Just make sure you use lube, even on the body mount bushings, otherwise you could develope some annoying squeaks.
1999.5 F350
4" Straight Pipe / Gauges (Pyro, Boost)
Wicked Wheel / Wg delete / Boost fooler
Tymar intake / Zoodad Mod / NChornet CCV mod
Hpx Crossover / Fuel CCK / ITP prepump tank mod
FPR Shim w/ underhood gauge
AIH Delete / Non Ebpv pedestal w/ valve delete
TW 6 position chip (will never own another canned toon)
3.73's / 6 speed manual 4x4
Still messin with it
Broncoguy is offline
post #5 of 6 Old 09-15-2008, 02:24 PM
Never mind then...
At least you got a free
~Mike Lewis
265,000MI
post #6 of 6 Old 09-15-2008, 02:33 PM
a truck
Matt P's Avatar
yeah go for energy suspension I have all their bushings in my 86
03 king ranch w/ a cummins
Matt P is offline
