will not run - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-26-2013, 04:20 PM Thread Starter
will not run
my powerstroke will not run. Fuses have voltage and check out good.I've replaced the ignition switch and swapped out the GPR.when I jump wire the GPR terminals the truck starts right up ,however I cannot turn the truck off until I pull the jump wire. Where else can I look to figure out this no run problem? Also the WTS light doesn't light up either. Confused:
therigwelder is offline
post #2 of 2 Old 12-26-2013, 06:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
My 97 wont shut off when you turn off the ignition
Look in here you may find your problem
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
