Dead pedal from 50-100% - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-26-2013, 05:01 PM Thread Starter
7.3 on 40s's Avatar
As title states my truck is becoming a dog, worse when warm. Pedal seems completely dead from half to full throttle. No change in engine reponse, noise, rpms, nothing ??????? When cold its had fairly decent power but ill have to get on it when cold here maybe tom and check on that.
Bad TPS???
97 F350 XLT CC LB 4x4 7.3psd 5spd White/Tan
-Straight Piped
-6637 Intake
-8in. Lift
-Welds w/40in. Rockers
-Warn hubs
-LSD w/4.56 gears
-Leather bucket seats
-Rhino lined
7.3 on 40s is offline
post #2 of 5 Old 12-26-2013, 07:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Sounds like you found it,
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 12-26-2013, 07:57 PM Thread Starter
7.3 on 40s's Avatar
Serious??? Maybe that simple huh?
Any other tests i should run well of course i could hookup meter and wires and go through all that but any symptoms you guys have off the top of your head when tps goes bad??
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
post #4 of 5 Old 12-26-2013, 08:07 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I turned my truck off and back on my dead pedal worked fine again, but also another time removed the chip it worked fine too
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 5 Old 12-27-2013, 05:58 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
the lack of power when warm says to me a problem with the HPO as it warms it thins and no longer provides the pressure you need. as if there is a cut/tear in the IPR allowing to much oil to flow past
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is online now
