1993 7.3L powerstroke - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By 351fifty
  • 1 Post By jjones96
post #1 of 8 Old 12-26-2013, 02:04 PM Thread Starter
What's the difference in the 93 and the 94-98 psd engine?
lpnsteve is offline
post #2 of 8 Old 12-26-2013, 02:27 PM
PSDTV21's Avatar
Well first of all 93 the 7.3 Powerstroke had not been introduced to the market yet. That is a 7.3 liter IDI. They have completely different injection systems and the psd has a turbocharger. Otherwise the 94.5-98 (PSD) engines have very subtle differences, like different belt/pulley thickness, but basically the same
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #3 of 8 Old 12-26-2013, 02:54 PM
alaskan155's Avatar
Quoted: 60 Post(s)
if i remember right its a completely different block, only sharing the displacement, engine mounts and bellhousing pattern.
so you Can Not convert a 7.3 idi into a power stroke but i believe banks sells a turbo kit for it.
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #4 of 8 Old 12-26-2013, 04:54 PM
m j
isnt the factory idi turbo based off of the ATS kit?
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #5 of 8 Old 12-26-2013, 06:43 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Pretty sure the factory turbo is an ats unit with out the aftermarket flair when you buy it from them instead of ford doing it
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 8 Old 12-26-2013, 06:46 PM
ryandamo's Avatar
ats was the factory kit, the only parts interchangable between a idi and a powerstroke are the oil caps thats it.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #7 of 8 Old 12-26-2013, 06:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Motor mounts
Pwnm30rdi3 likes this.
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 8 Old 12-26-2013, 09:32 PM
jjones96's Avatar
Drain plug
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
