cold start question - Ford Powerstroke Diesel Forum
post #1 of 22 Old 12-25-2013, 08:04 AM Thread Starter
dieselshield's Avatar
cold start question
Hey all,
My dad has a 95 f350 w/7.3psd, lately had developed a real cold start problem. All the glow plug components are new (plugs, harness, gasket, and relay) due to an unrelated repair performed a few months ago. Anyways, when unable to plug it in (like at work) he comes out and truck won't start. Cranks and acts like it wants to start but wont fire. Lots of white smoke out of the pipe while cranking. If the truck is plugged in it starts and runs fine, and runs smooth when warm. Im thinking possibly injector o rings? Just wondering if you smarter than me folks have any other ideas? I'm a 6.0 guy so I'm not too familiar with the 7.3 characteristics. Thanks for any advice offered. Just trying to get the old man back on the road while I'm up for Christmas.
2005 F-250 CC FX4
[SIZE="6"][COLOR="Blue"]
APR head studs & oem head gaskets
Warren diesel injectors - stock
OEM Oil Cooler
Dummy plugs & stand pipes
IPR egr gen 2 delete
Updated STC Fitting
Updated turbo train tube
'08 trans pan & filter
Dieselsite coolant Filter
EGT & Fuel PSI guage
Rotella Ultra ELC
Blue Spring
Updated HFCM drain
Riff Raff boots
4" Diamond Eye turbo back
Billet fuel filter cap
Ed's FICM-eco tune
High Idle Mod
Manual fan control
Torque Monitor
dieselshield is offline
post #2 of 22 Old 12-25-2013, 08:12 AM
Daves41's Avatar
Quoted: 5 Post(s)
I had a 95 7.3. Always had problems in cold weather. Kept burning up the glow plug relay. Never was able to figure out why. Used to get a year out of one, sometimes more. I carried a short jumper cable behind the seat. I would just jump the relay for about as long as the light would have stayed on, would start right up then. Was time to head on down to the International dealer for another relay. Replaced the glow plugs at 100,000, thought that might help, it didn't.
Daves41 is offline
post #3 of 22 Old 12-25-2013, 08:21 AM
gabegoforth's Avatar
Just cause it's been replaced doesn't mean it works. That GPR is probably shot. Try a Ford or International.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #4 of 22 Old 12-25-2013, 09:10 AM
Quoted: 22 Post(s)
Just went through this myself. Exactly the same problem... Turns out my GPR was bad.
Check with a volt meter.
Syndicated_cdn is offline
post #5 of 22 Old 12-25-2013, 10:59 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Sounds like your relay is bad. Turn they key on and jump the two big posts with a wire, if it sparks, gets hot, and the truck starts up fine then your relay is bad .... OR...... The control circuit is bad.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 22 Old 12-26-2013, 09:54 AM Thread Starter
I'll give that a shot and report back, thanks.
2005 F-250 CC FX4
OEM Oil Cooler
Updated STC Fitting
Rotella Ultra ELC
Blue Spring
Updated HFCM drain
Riff Raff boots
Ed's FICM-eco tune
High Idle Mod
Manual fan control
Torque Monitor
post #7 of 22 Old 12-28-2013, 10:07 AM Thread Starter
Ok, at 40 degrees, truck still won't start. Checked glow plug relay. Both large posts have 12v and one small one as well. Thoughts?
2005 F-250 CC FX4
OEM Oil Cooler
Updated STC Fitting
Rotella Ultra ELC
Blue Spring
Updated HFCM drain
Riff Raff boots
Ed's FICM-eco tune
High Idle Mod
Manual fan control
Torque Monitor
post #8 of 22 Old 12-28-2013, 10:09 AM
Hmm. Does the tach read when your cranking? Does the engine spin fast enough?
post #9 of 22 Old 12-28-2013, 10:09 AM Thread Starter
Also, with block heater pugged in, it starts like brand new. Just fyi
2005 F-250 CC FX4
OEM Oil Cooler
Updated STC Fitting
Rotella Ultra ELC
Blue Spring
Updated HFCM drain
Riff Raff boots
Ed's FICM-eco tune
High Idle Mod
Manual fan control
Torque Monitor
post #10 of 22 Old 12-28-2013, 10:12 AM Thread Starter
Yes to both. Also, white smoke still pours out of the tailpipe while cranking
2005 F-250 CC FX4
OEM Oil Cooler
Updated STC Fitting
Rotella Ultra ELC
Blue Spring
Updated HFCM drain
Riff Raff boots
Ed's FICM-eco tune
High Idle Mod
Manual fan control
Torque Monitor
