Fuel in radiator. HELP!! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-23-2013, 09:25 PM Thread Starter
Hi. I noticed fuel in my radiator today and I was wondering of it is ok to drive tonight because it's a plow truck and I need to go plow. PLEASE HELP!!
1997fordf-350 is offline
post #2 of 11 Old 12-23-2013, 10:01 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 114 Post(s)
Most likely you have cracked or leaking injector cups.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #3 of 11 Old 12-24-2013, 08:46 AM
PSDTV21's Avatar
^^^What he said. Can you drive it? Probably. Would I? No. Just an opportunity for more damage.
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #4 of 11 Old 12-26-2013, 07:44 AM Thread Starter
Ok called a garage and they said they need to pull the engine for 1300. We don't need to pull the engine do we?
post #5 of 11 Old 12-26-2013, 10:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Would cracked injector cups cause rad fluid in the injector holes? Kause I just cleaned that out and reinstalled my sticks
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 11 Old 12-26-2013, 10:41 AM
broncomitch's Avatar
NO, Stay away from that place. There screwing you.
With the right tool you don't even need to pull the heads.
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #7 of 11 Old 12-26-2013, 03:41 PM
PSDTV21's Avatar
^^What he said. Multiple places to get or maybe rent a sleeve removal tool. It may be easier on you if the engine is out but not worth the time and effort.
-Tyler
1994.5
PSDTV21 is offline
post #8 of 11 Old 12-26-2013, 04:06 PM
alaskan155's Avatar
Quoted: 60 Post(s)
you can buy the tools, sleeves and injector o-rings for less than what that shop is charging an have if fixed over a weekend, you can drive on it for a little while until it is fixed but the diesel will eat most of the rubber, thermostat gasket, and overflow tank if not treated asap.
this is the kit i bought, angelofish on ebay
7 3L 7 3 Ford Powerstroke Injector Sleeve Cup Removal Tool and Install Kit | eBay
he also rents the tool out for 200 with all the stuff you need to do the job. if you can change glow plugs you can do this job.
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #9 of 11 Old 12-26-2013, 07:33 PM
ryandamo's Avatar
if it where my truck i would replace all of the coolant hoses also after flushing it out a few times first
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #10 of 11 Old 12-26-2013, 08:32 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Anyone?...
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
