Track Bar Bracket tore off axle. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-23-2013, 03:47 PM Thread Starter
Exclamation Track Bar Bracket tore off axle.
So I noticed my track bar was hanging down this morning, the bracket has ripped off of the axle, it seems that the bracket is actually welded to the axle, any suggestions as to how I would fix it? It is pretty mangled and i do not foresee it being able to be welded, any input would be greatly appreciated.
Bad start to a Monday.
twducz1 is offline
post #2 of 13 Old 12-23-2013, 04:48 PM
PSDTV21's Avatar
I'm going to assume this is an f350. Could you post a pic to clarify what the problem is?
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #3 of 13 Old 12-23-2013, 09:08 PM
rusty1161 is offline
post #4 of 13 Old 12-24-2013, 07:42 AM
PSDTV21's Avatar
I'm pretty sure no. You need one from an obs
-Tyler
1994.5
PSDTV21 is offline
post #5 of 13 Old 12-24-2013, 09:06 AM Thread Starter
Hi, yes it is a F-350, I will post pictures when I get home.
Rusty that does look like the right pary, does that get bolted on with the u bolts that hold the axle or is it welded on, and what do you mean obs?
twducz1 is offline
post #6 of 13 Old 12-24-2013, 09:09 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
You broke your u bolt plate on the axle? Or at least thats what it sounds like. Those plates are welded to the axle and you really cant get them. To fix this you will be into some custom fab work
Trucks and parts............
kanuck15 is offline
post #7 of 13 Old 12-24-2013, 10:18 AM Thread Starter
twducz1 is offline
post #8 of 13 Old 12-24-2013, 10:22 AM
kanuck15's Avatar
Quoted: 10 Post(s)
Good lord! yeah those rot out sometimes but thats the first time Ive seen that before. You are definitely in for a custom job there. Thats not a reproduction part
kanuck15 is offline
post #9 of 13 Old 12-24-2013, 10:22 AM
post #10 of 13 Old 12-24-2013, 10:25 AM Thread Starter
Yea I live in Vermont so fighting rust is a constant battle. So there is no way to relocate it or anything? I have no way to engineer or weld a new one for myself which means I will have to bring it somewhere, which I'm sure will be $$$.
I really appreciate all your help and quick responses.
twducz1 is offline
