clutch longevity - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-22-2013, 08:16 PM Thread Starter
troykimber's Avatar
clutch longevity
how many miles r u guys getting out of u're clutches?
I've ran a zoom zvt ceramic 13" clutch for 55k and the buttons r down to the rivets. u would think it would last longer than that or maybe I need to step up to a double disc?
what has everyone else experienced?
95 sc lb 4x4 5 speed
ts 6 position chip, boost relief valve, 4" intake, 3" downpipe-5" rest of the way to a stack, fpr shim, twin 16" s-blade electric fans, poly bushings, zoom variable torque ceramic clutch with solid flywheel, hydroboost, stancor relay, exhaust brake, ss hpx line, 140v idm, bar and plate intercooler, glowshift gauges, gt grant signature series wheel with black billet hub, rockford door speakers- pioneer head unit- 2x 12" kenwood w3 subs
troykimber is offline
post #2 of 12 Old 12-23-2013, 02:57 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Unless you are slipping the piss out of it I have gotten over 300k out of a stock clutch
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #3 of 12 Old 12-23-2013, 07:02 AM
Quoted: 54 Post(s)
(Are you also worried about your keyboard wearing out?..... )
madpogue is offline
post #4 of 12 Old 12-23-2013, 11:05 AM
desertdeer's Avatar
My stock clutch in my 2000 went 60k, southbend ceramic went 40k, luk with a feramic disk went 80k and was holding up great when I sold my the truck.
I also had terrible luck with a ceramic clutch in my cummins work truck
96 F250 PSD 3''DP 4'' ATS EXHAUST 6637 TS-6 5-SPEED LUK CONVERSION INTERCOOLER PROPANE 4'' LIFT 35X18'S
desertdeer is offline
post #5 of 12 Old 12-23-2013, 01:32 PM
dr.deere's Avatar
Quoted: 19 Post(s)
I out a new luk in my 94 when I had Trans rebuilt it was still I'm good shape but I wanted to make sure everything was good. Had a jumping out of gear issue Trans shop thought pilot bearing was going the luk I took out had 135k on it and probably woul have run another 135 before it was shot
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #6 of 12 Old 12-23-2013, 06:43 PM Thread Starter
troykimber's Avatar
I do like the holding power of the ceramic and I don't slip it... pretty much let it out then step on the go pedal.
the ceramic does eat the flywheel too more so than organic. the lack of mileage is a concern especially when replacements are not cheap...
has anyone here put a 5r110 in an obs? I prefer to shift myself but maybe a built auto would be better in the long haul?
post #7 of 12 Old 12-25-2013, 10:41 AM
I had to replace my stock clutch at about 150K miles because a chunk of metal broke off of the pressure plate which had to be a manufacturing defect. The clutch material and flywheel itself looked brand new though. My truck is a zf-6 with stock power.
99' Powerstroke is offline
post #8 of 12 Old 12-26-2013, 04:53 AM
Quoted: 3 Post(s)
I think you are back-words South Bend uses feramic and Luk uses ceramic.
Peter
South Bend Clutch is offline
post #9 of 12 Old 12-26-2013, 05:57 AM
desertdeer's Avatar
No sir. My southbend was ceramic. And i had the luk built with a feramic disc.
post #10 of 12 Old 12-26-2013, 06:39 PM
ryandamo's Avatar
must be the driver never had clutch go bad that fast
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
