Lost power then died... - Ford Powerstroke Diesel Forum
post #1 of 34 Old 12-22-2013, 04:06 PM Thread Starter
PhilMac's Avatar
Hey guys,
Yesterday I was doing some running around in my '97 F-350 and just cruizing down the road at about 50mph I lost about 75% power and then 100%. The RPM's slowly dropped and I was able to pull into a gas station. It was idling but rough. After a total of about 40 seconds it cleared up and ran fine. I drove another 15 miles and stopped for about 30 minutes then got back in and continued home. After about 5 miles it started again, complete loss of power and had to pull over. This time the truck shut off. I got out took a look under the hood, didn't see anything out of place. Also checked the valve cover harnesses and they were connected and appeared to be ok. Got back in it and After trying cranking for about 30 seconds I got to fire up and I was able to limp another mile. I was only a half mile from home and had a very small hill to get up but it was having none of it. Pulled over for the last time, and it died. I could get it to start back up after 30-45 seconds of cranking and I could get it to rev up slowly to about 2500 rpms. but after 10-15 seconds the rpms would drop and it would either die or idle very rough for a few seconds then die. It seemed like i could rev it up then it would starve for fuel or maybe hp oil. Oil level is good, it did not smoke during any of this. It hasnt been real long since i put a fuel filter in it but im going to throw another one in it tomorrow. I replaced the fuel pump in the valley about 6 years ago (only 40k ish tho). When i crank it now it will try and fire a little but nowhere close to starting, sounds like 2 cylinders are hitting. Let me know if anyone has some pointers.
Thanks
'97 F-350 7.3 CCLB SRW ZF5 4x4
360,000+ miles
South Bend Stage 1
DP-Tuner - 40T,80T,80E,100P
Boost & EGT Gauge
DE 3" DP & 5" Exhaust
DIY 6637
'77 F-250 Highboy 460ci SCLB C6 4x4
Rebuilt 460ci
Comp Cam, P&P DOVE-C Heads, Holley 770cfm
Flat top pistons. 10.5:1ish compression
PhilMac is offline
post #2 of 34 Old 12-22-2013, 04:32 PM
JDoldnumber07's Avatar
Sounds like your Injector Driver Module (IDM) may have given up the ghost.
JDoldnumber07 is offline
post #3 of 34 Old 12-23-2013, 07:38 PM Thread Starter
PhilMac's Avatar
any way to test it or is it easier to steal one from a friend and swap test?
360,000+ miles
South Bend Stage 1
Boost & EGT Gauge
DIY 6637
Rebuilt 460ci
PhilMac is offline
post #4 of 34 Old 12-23-2013, 07:59 PM
Quoted: 7 Post(s)
It is best to steal a known good one from a friend.
I carry a spare with me now. I had a bad experience with a IDM. I was in a small mountain town on a Sat afternoon. I hooked up my trailer pulled it about 15 ft. right out into the campground road and there it died. The campground owner was nice enough to drive me into town to the Stealer Ship which was the only place that had one. 1K and 15min swap later I was back on the road. Now I keep an extra under my back seat next to my CPS
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is online now
post #5 of 34 Old 12-24-2013, 02:00 AM
dr.deere's Avatar
Quoted: 19 Post(s)
Check your fuel pressure my 97 acted very similar when the fuel pump died
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is online now
post #6 of 34 Old 12-24-2013, 03:55 AM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
Also pop the plug on the HPOP reservoir and look at the level... mine had similar symptoms when my LPOP went out.
fill res. then see if it will start for a couple seconds. If it does LPOP likely cause.
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
post #7 of 34 Old 12-24-2013, 06:51 AM
dr.deere's Avatar
Quoted: 19 Post(s)
If it was the loop it shouldn't have restarted that many times though. I had a lpop fail there was just nothing
post #8 of 34 Old 12-24-2013, 08:48 AM Thread Starter
PhilMac's Avatar
Swapped them idm and threw in a new fuel filter for good measure. Nothing. Still after about 30-40 seconds of cranking I can get it to barely fire off. Haven't checked the fuel pressure yet, got Christmas Eve lunch first. I know it's a dummy gauge but after cranking my oil pressure gauge is showing normal so I'm assuming the lpop is pumping.
360,000+ miles
South Bend Stage 1
Boost & EGT Gauge
DIY 6637
Rebuilt 460ci
PhilMac is offline
post #9 of 34 Old 12-24-2013, 10:12 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I would agree your lpop is working I would bet fuel pump went
post #10 of 34 Old 12-24-2013, 12:38 PM Thread Starter
PhilMac's Avatar
going to pick up a gauge shortly. what should the pressure be cranking but not running?
360,000+ miles
South Bend Stage 1
Boost & EGT Gauge
DIY 6637
Rebuilt 460ci
PhilMac is offline
