Is my truck rare? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 12-22-2013, 03:20 PM Thread Starter
CPauley's Avatar
Is my truck rare?
Hey guys, I picked up a 1994 single cab f250 about a month ago. The manufacture date is 3/94 and it IS a 7.3 direct injection powerstroke with a zf5 speed tranny. Has 4.10 gears and air shock on the back and a air valve to pump them up right below the side of the driver side seat. I always thought ford didn't start putting powerstrokes in f250s untill 6/94? My truck also has a obd1 plug under the hood and a obd2 plug under the dash. I tried the jumper wire test on the obd1 plug under the hood but it didn't work?? I'm having a time trying to figure out if it's been flashed for obd2. And it just did hit 147k miles.
CPauley is offline
post #2 of 20 Old 12-22-2013, 05:52 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
i believe the PSD appeared in 3/94. all the 94 PSD had speeds. they had both th eplug under the hood and the OBD II port under the dash, though they are facing a different direction. you can get the PCM flashed DP offers it, and your dealer will do it as well.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 20 Old 12-22-2013, 06:58 PM Thread Starter
CPauley's Avatar
It just has me stumped on the obd1 plug not working. I looked on the internet where to place the jumper wire, and I even looked in a Haynes repair manual and it said the same. The check engine light still didn't flash. The light is not on but it should have still flashed a system pass code. I looked for a obd2 flash sticker under the hood, but couldn't find one. A sticker could peel off easily though. The only reason why I'd like to find out, is so I can buy a edge evolution programmer. That way I don't have to buy and install a egt gauge.
-3/94 F250 Direct Injection Powerstroke
-147k miles
-All stock except for Bully Dog exhaust with muffler and cat delete
-16 inch Mickey Thompson wheels with 285 m/t tires
-4.10 gears, air shocks on the rear
-ZF5 speed trans
CPauley is offline
post #4 of 20 Old 12-22-2013, 07:26 PM
Heavy_GD's Avatar
Quoted: 1436 Post(s)
Feedback Score: 3 reviews
I know its simple, but are you sure the bulb works?
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #5 of 20 Old 12-22-2013, 07:43 PM Thread Starter
CPauley's Avatar
Yea it works because it comes on for about a second when I turn the key on. All the fuses are good to. I went to advance auto today and hooked it up to a scanner for gasser vehicles and it would hit and miss on communicating with the vehicle. I'd like to know 100% sure if it's obd2 before I dump $450 in a programmer.
-147k miles
-ZF5 speed trans
CPauley is offline
The Following User Says Thank You to CPauley For This Useful Post:
Heavy_GD (12-22-2013)
post #6 of 20 Old 12-22-2013, 07:51 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You still would need an egt gauge to monitor that, ford didn't put one in from the factory, and easiest way to tell if your obd2 works is hook something that reads a psd to it
Btw edge is junk compared to custom tuning
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 20 Old 12-22-2013, 08:07 PM
Heavy_GD's Avatar
where are you located? Maybe someone nearby has a scanner
GD
Heavy_GD is offline
post #8 of 20 Old 12-23-2013, 03:59 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Advance scanner is NOT designed to work on diesels
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #9 of 20 Old 12-23-2013, 06:35 AM
Quoted: 48 Post(s)
If there was even hit and miss communication, that means the interior port is active. So an AE, Interceptor, MT2500, etc. should communicate with it. Generic OBD-II scanner will read speed and RPM but that's about it; no codes.
madpogue is offline
post #10 of 20 Old 12-23-2013, 07:27 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
A scan gauge II works on obd2 trucks too if anyone had one of those around you
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
