coolant problem - Ford Powerstroke Diesel Forum
post #1 of 1 Old 12-22-2013, 04:17 AM Thread Starter
miller347's Avatar
coolant problem
ok guys i tried to search the fourm so if i missed it im sorry but here is my problem .
ok guys i really need some help here. ok dude brings over and 95 7.3 turbo. and has oil in coolant tank. but no coolant in oil. when i go to drain the coolant. the coolant in main radiator looks new .. though odd but whatever .ok well i do some digging around on web and seems everybody points toward oil cooler. ok so take oil cooler off, change the back gasket and all o'rings. get done with it . pour purple power in and add water to flush coolant out. and start it up and as soon as i start it up the top coolant hose builds so much pressure that coolant cap starts pouring out water and springs a leak at thermostat , so take stat out and try it and start it back up. and still pours water out coolant cap and top raid hose is very tight within 5 seconds after starting it up ?? then try to back flush the system then . and try it again and still same too much pressure. only not they r water in the oil . and they wasn't b4 ?? any advice ? i mean its odd that they was no water in oil b4 and the radiator was full of new coolant but coolant tank was almost straight oil
05 f350 6.0
sct livewire ts with custom tunes from vivian at quick tricks
studs
egr delete
blue spring upgrade
updated stc fitting,dummy pipes,stand pipes
new 35x13.50x18 mickey Thompson mtz rubber
90 mustang turbo drag car
lol too much to list but what get done if it dnt have 500 whp then ima sell it !
92 toyota p/u 4wd lifted 33x12.5
beat around the farm with sold!
87 mitsubishi mighty max 53k original miles. gas sipper
paid 900 for it !!!
miller347 is offline
