96 powerstroke wont start after timming cover replavement - Ford Powerstroke Diesel Forum
post #1 of 35 Old 12-21-2013, 07:48 PM Thread Starter
plowguy1225's Avatar
i just replaced the timming cover refilled the fluids and the hpop and the truck will not start any ideas sometimes it sounds like it wants to but it wont thanks for any help
plowguy1225 is offline
post #2 of 35 Old 12-21-2013, 10:52 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
Sounds like air in the high pressure oil system it has to be worked out before it will run
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #3 of 35 Old 12-22-2013, 05:09 AM Thread Starter
whats the best way to do that
post #4 of 35 Old 12-22-2013, 10:18 AM
Quoted: 3 Post(s)
Crank it till it fires but give the starter some love while doing it by letting it cool down after 15 seconds of cranking. I've heard wd40 in the intake will ignite and run the engine till the injectors get enough oil to open on there own. After it starts run it down the road for 50 miles to work the air out
post #5 of 35 Old 12-22-2013, 12:28 PM Thread Starter
still wont start and the oil from the hpop is draining into the pan i have put 2 quarts in it
post #6 of 35 Old 12-22-2013, 12:35 PM
theforeman57's Avatar
Quoted: 4 Post(s)
sounds like you have interchanged front covers with an early / late engine. early 95 had an anti drainback feature or something like that, I will try and find the specs and why exactly your cover wont work.
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #7 of 35 Old 12-22-2013, 12:38 PM Thread Starter
thank you any help would be great
post #8 of 35 Old 12-22-2013, 01:03 PM
Quoted: 4 Post(s)
What year is your truck? I found that you can not swap a pump from a 96 - 97 into a 94.5 - early 95 motor, as the later pumps do not have a check valve to keep oil in the reservoir, as the front cover has that incorporated, and if you swapped a front cover from a early motor onto your late motor you do not have any anti drainback system in place.
So it sounds like you need to check your numbers, serial number #201681 and below have anti drainback systems in the pump, while later have it in the cover. And no problem
Axel --> 16yo
post #9 of 35 Old 12-22-2013, 01:07 PM Thread Starter
my truck is a 96
post #10 of 35 Old 12-22-2013, 01:13 PM
Quoted: 4 Post(s)
and the year of the front cover?
if the cover is early then you can swap a hpop ( stock, 17*, adrenaline,etc) that is modded to contain the check valve. why did you swap covers?
Axel --> 16yo
