Drivetrain issues. Read my issue, maybe you can help... - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 44 Old 12-19-2013, 12:08 PM Thread Starter
Interior Guru
weareweird69's Avatar
Quoted: 104 Post(s)
Feedback Score: 3 reviews
This has been an ongoing issue. If the truck is in 4wd, it will vibrate BADLY, as to where the dash actually moves up and down. It feels like something out of balance.
Wont do it with the hubs unlocked, and the transfer case unlocked
Wont do it with the hubs unlocked, and the transfer case locked in 4HI
Wont do it with the hubs locked, and the transfer case unlocked
Wont do it in 4LO, cant get above 10mph.
Wont do it in 2WD at all
Took out the front shaft, locked the axle in, locked the case in, wont do it.
Does it in reverse and forward.
Replaced BOTH Universals in front driveshaft, had the shaft checked for balance, and taken apart and inspected by a VERY REPUTABLE shop. Replaced the transfer case with a known good case. Still have the bad vibration in 4wd. The dash literally shakes up and down. The track bar, and radius arms are tight, and under 5000 miles. The front axle was serviced under a year ago with new universals and a new gear set.
SO, what could cause the issue I am having? Its almost like its in the front axle, but WHAT COULD IT BE?
Rear axle has been totally serviced, and all new universals in the rear driveshaft except for one, it still is good, and moves freely.
Any ideas?
-Garrett
Too many projects. Too little time...
weareweird69 is offline
post #2 of 44 Old 12-19-2013, 01:03 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
The yolks? considering the shaft is what is being shook
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #3 of 44 Old 12-19-2013, 01:08 PM
Quoted: 8 Post(s)
You seem to have ruled out the drive shift which would have been my first thought. Has the front or rear axle been changed? Maybe the gear ratios don't match? Is the vibration moving in a straight line e or turning?
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #4 of 44 Old 12-19-2013, 01:10 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I second the bearing on the yolk of the axle
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 44 Old 12-19-2013, 01:14 PM Thread Starter
Interior Guru
Quoted: 104 Post(s)
Rear axle has new bearings. Front axle has good bearings. Drive shafts are totally new minus one universal in the rear. Still in good shape. No play in anything. Or tight spots either.
They are 06 axles. I had the 4:10's removed and replaced with 3:73's. I'm just curious if they screwed up and installed a wrong gear set back in. Or if its the driveshaft angle. I'm about 5" over stock height.
-Garrett
post #6 of 44 Old 12-19-2013, 02:08 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Open front diff, not posi or limited? Jack the fronT up and lock the hubs. Count the rotations of the pinion joint to one rotation of a tire and match it to the rear doing the same thing. If they match then the ratios are the same.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #7 of 44 Old 12-19-2013, 02:16 PM Thread Starter
Interior Guru
Quoted: 104 Post(s)
Front is open. Rear is limited.
Isn't it 1 tire up. 2x tire revolutions for open
And then 2 tires up. 1x revolutions for limited slip or locked?
-Garrett
post #8 of 44 Old 12-19-2013, 02:23 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Yes, I just didn't know your combination of traction parts.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #9 of 44 Old 12-19-2013, 02:24 PM Thread Starter
Interior Guru
Quoted: 104 Post(s)
That's why we clarify! Haha
-Garrett
post #10 of 44 Old 12-19-2013, 05:08 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
I would be pulling diff covers and checking gear ratios
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
