EBPV discussion - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-19-2013, 07:32 AM Thread Starter
Hoover97's Avatar
EBPV discussion
Does anybody want to give me any info on the EBPV? Are there any delete kits? Or should I screw the delete and leave it?
97 7.3 regular cab 4x4, s&b intake, Diamond Eye 5" straight pipe, tuned by Tony Wildman
Hoover97 is offline
post #2 of 12 Old 12-19-2013, 07:40 AM
erics diesel's Avatar
is yours leaking oil? if so I would say delete it. there are 2 ways to do it the first one you remove the butterfly and plug the hole with a freeze plug and remove the rod assembaly from the pedestal and plug that hole with a bolt. the second is buying a deleted pedestal and outlet piece like these
1994 - 1997 Non-Exhaust Back Pressure Turbo Pedestal
High Flow Turbo Outlet 94 1/2 - 97 TP-38 Turbo
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 12 Old 12-19-2013, 07:52 AM Thread Starter
Hoover97's Avatar
I'm pretty sure it's not leaking but is there a possibility that it can get stuck?
Hoover97 is offline
post #4 of 12 Old 12-19-2013, 07:59 AM Thread Starter
Hoover97's Avatar
It's not leaking oil, but I think it's getting stuck when I drive. If that's even possible? And would I have to take the turbo out in order to put all the stuff on?
Hoover97 is offline
post #5 of 12 Old 12-19-2013, 08:06 AM
cthom388's Avatar
This is the best write up i could find, and it is the one i followed.
Gutting the Exhaust Back Pressure Valve - 1994-1997 Power Stroke FAQ
1995 F250 4X4 Zf5
  • TS 6 POS Power-Struck Tunes
  • 3" Silverline Dp to Straight Pipe
  • Custom E-Fuel/Regulated Return
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #6 of 12 Old 12-19-2013, 08:10 AM
there is a wire plug on the drivers side of the turbo try unplugging it and see what it does
post #7 of 12 Old 12-19-2013, 09:14 AM Thread Starter
Hoover97's Avatar
How much of a difference have you seen on your cold starts?
Hoover97 is offline
post #8 of 12 Old 12-19-2013, 11:09 AM
cthom388's Avatar
It doesnt really affect your cold starts the ebpv is just suspose to close off when its cold to make the engine warm up quicker.Taking it out will give you better mileage because the valve won't be shut and making the engine work harder while you are driving. It also gives better air flow because even though it is open, the valve takes up about a 1/3 of the area inside the pipe.The reason i removed mine was because the carbon build up in the butterfly was causing it to stick closed sometimes.
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #9 of 12 Old 12-19-2013, 12:37 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
What size resister do you use
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #10 of 12 Old 12-19-2013, 12:44 PM
cthom388's Avatar
I guess i do not know what resistor it is your talking about lol
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
