fuse #22 keeps blowing - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-19-2013, 04:25 AM Thread Starter
started the truck yesterday morning and was driving to work then it just dies. ended up being the fuse so I swapped it with the trailer control fuse and it got me to work and home. the truck sat all night, started it this morning, went inside to let it warm up and 5 minutes later it popped again. tried swapping it and it blew right away. so now it's something serious. is it my fuel bowl heater going bad and shorting out? please help I need this fixed before the next snow. fuse #22 keeps blowing-imageuploadedbyag-free1387455865.230414.jpg
tony0713 is offline
post #2 of 10 Old 12-19-2013, 05:42 AM
dr.deere's Avatar
Quoted: 19 Post(s)
Unplug the fuel heater first and then see if it still blows the fuse. Connector us down in the drivers side if fuel bowl
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 10 Old 12-19-2013, 08:11 AM
jake-96-7.3's Avatar
Send a message via Yahoo to jake-96-7.3
What he said ^^^^^ unless u live in cold climate it's not needed I live in pa and mines been unplugged for over a year still no issues
1996 F250 ext cab long bed
AFE stage 2 intake
Ts6 chip Tw tunes
Isspro EV2 Gauges
Dacco billet cover triple clutch HD Torque converter
3in down pipe
5in straight pipe
6 in tip,
true cool 40,000btu trans cooler
203 thermostat
Firestone ride rite air bags in rear
tinted head lights turn signals markers sd tinted fogs
Kenwood head unit
full JL audio sound
jake-96-7.3 is offline
post #4 of 10 Old 12-19-2013, 08:21 AM Thread Starter
I'm in pa also. just outside of Philly.
tony0713 is offline
post #5 of 10 Old 12-19-2013, 08:23 AM
jesilvas's Avatar
Quoted: 2 Post(s)
You figured it yourself, bowl heater.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 10 Old 12-19-2013, 08:27 AM
dr.deere's Avatar
Quoted: 19 Post(s)
As long as your running winter fuel it's not necessary at all I know of some that are running unplugged in 20 below temps with no issue
dr.deere is offline
post #7 of 10 Old 12-19-2013, 10:13 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
That and after about ten minutes of running the fuel returning from the head is REALLY hot.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 10 Old 12-19-2013, 04:28 PM Thread Starter
just pulled the wire for the heater. the upper wire that has a square rubber boot. put a new fuse and fired right up. let's hope that's the problem. fuse #22 keeps blowing-imageuploadedbyag-free1387499282.469671.jpg
tony0713 is offline
post #9 of 10 Old 12-20-2013, 07:24 PM
desertdeer's Avatar
I removed my heater about a month ago. Its been below zero here and i have had no problems. I put some white bottle diesel clean in it each tank
desertdeer is offline
post #10 of 10 Old 12-21-2013, 06:41 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I actually have #2 in both of my trucks right now with stanadyne performance formula and it's -10 with -40 windchills last Sunday sat outside for 24 hrs plugged in for two fired it up let it run for about 45 min while I helped a buddy push snow then got on the highway and drove home no prob. His tractor in the other hand had howes in it and 2 cuz it doesn't get used much that gelled up on me
dr.deere is offline
