Glow plug questions - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-18-2013, 10:10 AM Thread Starter
Glow plug questions
Okay so my truck sucks to start in the morning, even with it plugged in all night. I think the block heater is not working at all but that's a separate issue.
I am going to replace all 8 glow plugs and the relay with a bigger relay. My question is two-fold:
Is there a pictorial of how to change them out?
More importantly - when I do change them out, do I need to change the UVC gasket and the GP harnesses?
For example on ebay:
94 97 Powerstroke 7 3L Diesel Glow Plug Kit Gaskets Harnesses 8 Plugs Pigtails | eBay
Or is this just an unneeded expense?
1996 F350 CC LB....
majorpecs is offline
post #2 of 8 Old 12-18-2013, 10:37 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
First off dont use anything but motorcraft ZD11 glow plugs. Anything else seems to have issues breaking off in the head.
Secondly the best way to determine if you need all that is take a look at the plugs going into the valve cover gaskets. If they look burnt at all or have bad ends its a good sign you may need all that. A lot of guys just replace what is bad but I am one who replaces all of it at one shot.
I dont know of any pictorials but it is really straight forward once you get the valve covers off (the hardest part actually). I reccomend a 10 inch piece of 1/4 inch fuel line to get the glow plugs out as they sit down inside the head pretty well. I have an engine on a stand I could take some pictures of if you really need it?
Trucks and parts............
kanuck15 is offline
post #3 of 8 Old 12-18-2013, 10:42 AM Thread Starter
No I don't think I need pictures, but I appreciate the offer. My question now is, what does 1/4 fuel line have to do with getting the plugs out?? What tool do I need to get the old plugs out?
1996 F350 CC LB....
post #4 of 8 Old 12-18-2013, 10:57 AM
kanuck15's Avatar
Quoted: 10 Post(s)
Just use a deep well 1/4 drive 10mm socket to loosen the glow plugs. The issue a lot of guys run into is their socket hits the rocker arm and it wont come out. So what I use the hose for is to slip over the end of the glow plug once its loose and turn it out that way. Obviously use the socket to break the plug free and run it out a few turns but the hose does the rest.
kanuck15 is offline
post #5 of 8 Old 12-18-2013, 11:04 AM Thread Starter
Got it...thanks!
1996 F350 CC LB....
post #6 of 8 Old 12-18-2013, 12:07 PM
theforeman57's Avatar
Quoted: 4 Post(s)
also, make sure that your locking mechanism on your socket is good, or use some electrical tape to secure it to the extension. Not entirely uncommon for your socket to fall down into the oil passages.
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #7 of 8 Old 12-18-2013, 12:55 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
this. i don't have a 1/4 deep 10mm so i used a 3/8 then take it off and use a pice of hose to get the old one out and the new one started. for parts tousely ford has great prices and pretty quick shipping. ford wants $18 apiece for GPs tousley ford wants 8.xx. (i know because i just ordered 8 to do one of my trucks)
it appears tousley has changed their name
AutoNation Ford White Bear Lake | White Bear Lake New & Used Ford Dealer serving Minneapolis, Roseville & St Paul Minnesota
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 8 Old 12-18-2013, 02:06 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I used a 10mm deep well 3/8 drive socket, literally last week to install/remove glow plugs, think I paid 8-10$ each on amazon shipped, to make removing the pass side valve cover easy tho take the bolt off that small box on the side of the blower motor box, save yourself some headache, I didn't use any fuel line for this tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
