??? Low Range Light...... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-18-2013, 02:58 AM Thread Starter
Ranzan's Avatar
Quoted: 23 Post(s)
have had some slick roads here the last several days so i locked it into 4x4 high after 5 minutes the low range light came on.. shifted back into 2 both lights went out shifted back into 4 and now both 4x4 and low range wont turn off even in 2 wheel....
is there a sensor on the transfer case that can go bad or maybe my linkage is messed up ??
my transfer case isnt howling or grinding and seems to be working just fine
this is on a 5 speed manual crew longbox
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #2 of 3 Old 12-18-2013, 05:17 AM
Quoted: 59 Post(s)
It's most likely the switch on the t-case. You should be able to tell by how the truck behaves whether it's actually shifting from 2WD to 4HI to 4LO. IIRC, it's one switch, with two contacts, one grounds out to turn the 4x4 light on and the other grounds out to turn the Low Range light on.
How old is the fluid in the t-case? Maybe if it's old, the switch is gummed up.
madpogue is online now
post #3 of 3 Old 12-18-2013, 12:51 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
what madpogue said i think a new switch is 40ish dollars.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
