LED bulbs - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-17-2013, 06:54 PM Thread Starter
jake-96-7.3's Avatar
Send a message via Yahoo to jake-96-7.3
LED bulbs
so havent been able to find a clear answer ive read hundreds of times that u cant use led bulbs in our trucks some say is just with the tail lights some say its the entire truck without a resistor i know the tail lights is true but what about the rest of the truck
1996 F250 ext cab long bed
AFE stage 2 intake
Ts6 chip Tw tunes
Isspro EV2 Gauges
Dacco billet cover triple clutch HD Torque converter
3in down pipe
5in straight pipe
6 in tip,
true cool 40,000btu trans cooler
203 thermostat
Firestone ride rite air bags in rear
tinted head lights turn signals markers sd tinted fogs
Kenwood head unit
full JL audio sound
jake-96-7.3 is offline
post #2 of 11 Old 12-17-2013, 07:00 PM
As long as the bulb isn't a "flasher" (turn signal, etc) you can use LED bulbs without modifications.
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #3 of 11 Old 12-17-2013, 09:21 PM Thread Starter
so a led third brake light and bed lights wouldnt work without a resistor since the third brake light is a flasher?
post #4 of 11 Old 12-17-2013, 09:51 PM
SuperCrutyPS's Avatar
Quoted: 304 Post(s)
Garage
The reason resistors are needed is that the flasher unit is based on a load of the circuit. LEDs have a lower load, so you get a fast flash conditions when using the turn signals.
The TBL is not a flasher, it is a brake light. The brake lights will work fine. The bed lights will work. This is a turn-signal issue.
You also may want to check at the auto parts store to see if there is an electronic flasher that will fit your truck. There is for Super Dutys, I have one in my truck.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 11 Old 12-18-2013, 06:39 AM Thread Starter
Alright cool thanks guys just wanted that cleared up
AFE stage 2 intake
Ts6 chip Tw tunes
Isspro EV2 Gauges
3in down pipe
5in straight pipe
6 in tip,
203 thermostat
Kenwood head unit
full JL audio sound
post #6 of 11 Old 12-18-2013, 03:08 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
If a resistor is not done for the brake lights the Trans WILL act up if it's auto, if stick it won't matter
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 11 Old 12-19-2013, 09:22 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I dont have any problems Kris?? And im pretty sure neither does Matt?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #8 of 11 Old 12-19-2013, 10:09 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
My brake lights have resistors built into them....and I have an electronic flasher unit
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #9 of 11 Old 12-19-2013, 10:12 AM
Chapter Director
Quoted: 5 Post(s)
Well shoot that might be why Maybe ill swap some regular bulbs back in and see if my trans acts any different but i really didnt notice any change after i did it but i have developed a grind at high rpms but idk maybe its a u joint.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 11 Old 12-19-2013, 10:19 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
Naw, bulbs won't do that. The turn signal system is using the same high side filament as the brake system to light the bulb. Since the LEDs, as perfectly stated before, do not eat all the appropriate energy that is supplied buy the turning system the unused energy back feeds through the TBL and back to the switched side of the BOO switch. The PCM seeing this loose energy then thinks that the BOO switch was activated and kicks the trans out of overdrive. Nothing like hauling horses over a hill and go to change lanes to have the trans start bucking in and out of overdrive in time with the turn signal switch.
Matt
'97
-Stage II trans.
BigFuel is offline
