HPOP reservoir empty - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-17-2013, 08:09 AM Thread Starter
Hi Guys, I could use a little help with my latest problem. This past summer I didn't drive my truck ('96 7.3) for about 2 weeks. When I tried to start it...no go. Discovered the high-pressure oil pump reservoir was empty. Filled it, she fired right up. Now (in the cold Wisconsin winter) with regular driving she starts fantastic (It's plugged in on cold nights). After about 10-15 seconds it dies. She'll fire up again and run for about 5 seconds the 2nd time and die. It runs shorter with every try until it just turns over with no fire. Reason being...the HPOP reservoir is empty again. I can usually get it going by filling it back up again but I can't keep going like this. Have any of you experienced or heard of a problem like this before? I would appreciate any thoughts as to what the problem is and what repair needs to be made. Thanks Dale
Dale Hackbarth is offline
post #2 of 4 Old 12-17-2013, 08:34 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
I'd suspect the lpop is going out
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #3 of 4 Old 12-17-2013, 10:44 AM
Twisty's Avatar
Watch out filling the HPOP res to get it going. The oil makes its way back into the oil pan. If you're not careful you could overfill the crankcase by a lot. I remember a thread a while back where a guy bought a truck for his son with this exact problem. He did the LPOP and all was well.
Good luck!
1996 F350 CCLB: ZF5 with Valair clutch, Rosewood stage 1 injectors, T500 HPOP, PHP tunes, Tymar intake, 5" straight exhaust.
Twisty is offline
post #4 of 4 Old 12-17-2013, 11:11 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Get a real cheap gauge 1/8 npt gauge and hose with a 1/4" nptm fitting on the end and install it on your hpop reservoir where the inspection port is and start the truck and watch the pressure while running, it should be ~50 psi at idle and up to 100 while revving.
Then find the port down by the oil cooler, its right where the trans meets the engine, its a 4 sided male head plug(not the ones on the block with a female hole and not the one on the cooler directly) that is 1/8 npt. Move the gauge there and read that pressure while running and it should have about the same reading as the top side. Just be quick because that port will leak oil once its open so just be quick and you will be fine.
If it is the same reading then yes chances are you have a bad lpop but if they are different then you just maybe losing pressure somewhere. Its a cheap check before buying a new lpop and going through putting a new one if you dont actually need it
Edit: and yes what he said ^^ id check your oil level before you do anything else if youve filled it multiple times
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
