Intake question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-16-2013, 10:35 AM Thread Starter
Intake question
96 F350 - So i just bought the truck friday and when looking at the engine, the intake system has a sort of ram air cowl on the front that faces the hood. Is this a stock piece? If so, do the aftermarket open intake systems tie into this forced air system?
1996 F350 CC LB....
majorpecs is offline
post #2 of 5 Old 12-16-2013, 01:32 PM
Arcturus's Avatar
That is stock air cleaner. No need for ram air and if you look at the stock air cleaner it too is not ram air. The 6637 mod has such a large surface from which to draw air no ram air is needed. The turbo should pull as much air as is needed.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #3 of 5 Old 12-16-2013, 02:42 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Ram air is useless on a turbo
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 12-16-2013, 02:45 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
So your saying you can't "Ram" the "Crammer"
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 5 Old 12-16-2013, 02:50 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Basically
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
