opti lube xpd vs Super Tech 2 Cycle oil
I've been using Super Tech 2 cycle oil for about 6 months now as an additive and there is a big difference on how it runs over ulsd. But has any one been using the opti lube xpd or switched from super tech to opti lube and noticed any difference?
i ran trany fluid and it has helped to lube the inter parts i noticed last time i took her apart she was alot less dirty
Trans fluid didnt lube anything in your fuel system what it did was act like a detergent and clean stuff up. Trans fluid actually takes away from the lubricity of the fuel these days
sorry for bringing out my ignorance, but yall run 2 cycle oil and tranny fluid in your fuel?
2 cycle here, do not run tranny fluid.
2 cycle 1 oz. per gal. Will help with lubricity, and noise. Supposedly will help with fuel economy, I did not see a difference. Make sure it is ashless. |
every fill up or just once and a while? Like using lucas?
As often as you wish.
I stopped every fill up and do it every 2-3 fill ups now. |
I use one oz per gallon of the 2 cycle and have never had a problem. roughly 16 oz each tank every fill up.
OK, yesterday at work i looked at all the diesel fuel addatives we sell and heres a short list:
-Power service diesel kleen -seafoam -howes lubrication -diesel power! -lucas -B-12 -marvel mystery oil -red line diesel catalyst -FPPF fuel power -GUNK sulfur substitute obviously a few ounces of 2cycle oil or some tranny fluid is cheaper than those listed above. So has anyone used any of the commercial ones and noticed a difference? When I got the truck I got a gallon of lucas and filled the fuel filter housing up when i changed filter and poured the remaining 3/4 gallon in the tanks. didnt notice a difference in the was she ran or mileage. |
I'll run 6 oz of lucas in each tank every few fill ups. Sometimes it seems like it does something othertimes it doesn't. I think its all in my head.
