Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L General Powerstroke Discussion
  #21 (permalink)
Old 08-10-2008, 12:46 PM
somebodyelse5 somebodyelse5 is online now
i think you bypass the map sensor? im not positive, im not sure if i can do it on my truck, so i never did much reading up on it.
basically it doesn't allow the computer to adjust the amount of fuel going in for more total burn. so it just dumps it. I think.
someone on here can help you out for sure.
higher altitude also = more smoke!!
  #22 (permalink)
Old 08-10-2008, 08:38 PM
southern7.3 southern7.3 is offline
Powerstroke Fanatic
Originally Posted by flowmasters40 View Post
i am just worried about the stock downpipe it flatens out but i think maybe the straight will gain some of that power back
The exhaust gases can only flow as fast as they can move through the smallest (diameter) part of the pipe. You might get some power back but to get the full effect get a full 4" TB. Ive got the stock exhaust system just with no muff dumped in front the tire. Its fine but I will be upgrading to a dual 4" TB around Christmas
  #23 (permalink)
Old 08-10-2008, 11:27 PM
POWERSMOKIN POWERSMOKIN is offline
the obs trucks cant dump that much fuel in, even full on. i believe its like 100ccs for single shots, and 120ccs for split shots?? iono. i could be wrong..
  #24 (permalink)
Old 08-11-2008, 12:12 AM
PSD0389 PSD0389 is online now
OBS-Old But S.exy
Send a message via AIM to PSD0389
You cant do a smoke switch on a OBS and unplugging the map sensor wont do much for smoke, if you want a good amount of smoke without spending alot on injectors and other supporting mods get a Tony Wildman chip with a smoke tune and you'll be able to roll a decent amount of coal
Heres my 95 with a wildman chip on smoke tune
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
