Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L General Powerstroke Discussion
Old 08-06-2008, 07:24 PM
SuperDuty73 SuperDuty73 is offline
Fuel pump
How is the fuel pumped into the heads? Is it sent through the back of the motor and the regulated return out the front?
Old 08-08-2008, 06:45 PM
Old 08-08-2008, 06:52 PM
bigcountrysg bigcountrysg is offline
Countryboy Mechanic
It goes from the pump to the fuel water seperator to heads, then to the injectors then to the return line back to the tank.
Old 08-08-2008, 06:54 PM
Yeah I know that but what side does the fuel enter into the heads, From the front of the engine or from the back?
Old 08-08-2008, 06:57 PM
Countryboy Mechanic
That I do not know. I think it enters both heads. Do you have a fuel leak and diesel in the engine valley.
Old 08-08-2008, 07:07 PM
I have no fuel leaks, but I also know it enters both heads seperate but am unsure of wether or not its threw the front or back of the motor.
Thanks!
Old 08-08-2008, 07:21 PM
Countryboy Mechanic
Thanks!
It enters the heads where the fuel water seperator is at. if you remove the fuel filter housing you will see where the fuel enters the heads. So that would mean that the fuel enters at the frontend of the heads.
Old 08-08-2008, 07:35 PM
h2odrx h2odrx is offline
the pump is two stage the top fills the filter and the bottom high pressure sends the fuel to the back of the heads via the banjo nut......
The return is at the front....
Old 08-09-2008, 01:39 PM
alberta 7.3 alberta 7.3 is offline
First, fuel is draw up from the tank in the "lift pump" stage of the pump, then goes to the filter/water separator. Secondly, fuel is drawn from the filter and pressurized in the pumps second stage, where it flows through the Banjo fitting, as h2odrx mentioned, into the back of the heads. fuel fron the front of the heads returns to the regulator mounted on the filter/water separator, and exits the regulator to a return line.
Old 08-09-2008, 07:01 PM
yes that is it and now I cant get the banjo bolt back in?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
