Cheap Spunk - Ford Powerstroke Diesel Forum
Old 11-06-2006, 02:14 PM
Cheap Spunk
I have discovered (maybe an old trick but i just tried it) a power adding trick thats cheap and i have seen no problems associated with it. The trick is to put 1 gallon of the lowest octane gasoline in a tank of diesel. it gives a noticable improvment in power and throttle response. anybody heard any problems that can happen from doing this.
Old 11-06-2006, 02:45 PM
I would definately like to hear some input on this. How much difference was there?
Old 11-06-2006, 02:47 PM
there was a noticable difference between that and just regular diesel
You may very well get away with it in a 7.3, but it is not advisable for a 6.0 since their injectors are very sensitive to water. Gasoline most places these days contains enough ethanol to bond with any minute amount of moisture that may be in your tank and pass it through the water seperator and onto the injectors. Not a cheap fix or affordable fix on the best of days.
Old 11-06-2006, 02:55 PM
but makes the 7.3 scat though
Old 11-07-2006, 08:32 AM
That sounds like a very bad idea. Who gave you this idea. I cant imagine the diesel fuel and gasoline would ever mix.
Old 11-07-2006, 08:47 AM
I don't know nuttin....
This is DEFINATELY a bad idea...
Old 11-07-2006, 09:32 AM
im fat and ugly
found this article on the topic
Old 11-07-2006, 09:43 AM
FYI: I had a 81 rabbit diesel, they recommended adding gasoline to the tank up to 25% concentration to combat winter gelling. But this manual is 25years old now.
Old 11-07-2006, 11:51 AM
no more gas for me
by reading the article and knowing that next year they will be putting even lower sulfer content in diesel i will have to stop doing that even though it gives power. thanx for the motor ruining preventative info
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
