Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L General Powerstroke Discussion
Old 08-05-2008, 08:31 PM
95dieselsmoke 95dieselsmoke is offline
DIESEL DORK
OBS f350 springs to f250
ok guys/gals. a buddy of mine has a 97 f350 that he just lifted. so he has his stock springs that he said i could have. I know there is a RSK and SD spring setup for my f250. but i am curious if his OBS f350 springs would work for a similar setup like the RSK setup for my truck. will they bolt right up? or am i out of my mind? any ideas/answers are appreciated. thanks
Old 08-05-2008, 08:53 PM
tinlizzy tinlizzy is offline
If you have twin I beam front axle, and the 350 leafs lift the truck a little, then you may need to modify/extend the mounts at the center of the axle to keep the axle straight.
Old 08-05-2008, 09:00 PM
HMM HMM is offline
I wish you were close to me here in tennessee, I'm closing the deal on a 97 f250 thursday that has a 6 in lift. I'm going to look for someone that wants the lift that will trade me the stock stuff.
Old 08-06-2008, 09:03 PM
DIESEL DORK
that would be sweet, if only you wernt across the country im sure you wont have a problem finding someone to swap you
Old 08-07-2008, 02:16 PM
DIESEL DORK
anybody know if these 1 ton springs will work with a little fabrication?
Old 08-07-2008, 02:35 PM
Nick Nick is offline
Whats up after reading your post I might be able to help you. I have a 96 f-250 that has been converted to a dana 60 front end, but still has stock suspention in the rear with a 2 inch lift in the front from an add a leaf. Let me know if you want to work out a deal. Why dont you want the left?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
