Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L General Powerstroke Discussion
Old 08-05-2008, 05:16 PM
dondre47 dondre47 is offline
help with fuel system pls!!
hi i am having aproblem with my 95e350 7.3. my truck was idling for about 5 min and i noticed it started running rough and loud. i shut off the truck and now it wont start. i'm guessing its a fuel problem. i located the fuel filter but i cant find the drain. im lost here as i'm new to diesel. does anyone know were i can drain the water out of the system or where the fuel pump is located or the primary pump. thanks
Old 08-05-2008, 06:01 PM
donald lorbeske donald lorbeske is offline
If it any thing like my 97 the drain is on the front left side of the bowl might be a yellow handle
Old 08-05-2008, 06:08 PM
sea71 sea71 is offline
It's just me
Just another thought. How about engine oil? Enough in it?
Old 08-05-2008, 06:45 PM
[quote=donald lorbeske;685653]If it any thing like my 97 the drain is on the front left side of the bowl might be a yellow handle[/QUOTE
I did see that yellow handle tried pulling, twisting but i was unsure what it was. now that i know i'll take a better shot at it. do you knwo where the primary pump is located
Old 08-05-2008, 06:47 PM
engine oil is fine
Old 08-06-2008, 06:18 AM
SMKSTAX SMKSTAX is offline
<-----ANY QUESTIONS??
Could be your CPS also.
Old 08-07-2008, 01:03 PM
wbones9 wbones9 is offline
try switching tanks
the yeloow handle swings; being pointed toward the front or fender. It doesn't twist, pull, etc...
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
