Seafoam in your diesel fuel - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-03-2013, 05:19 AM Thread Starter
AddictedOffroad's Avatar
So, I have been of the thinking that Seafoam is pretty much an Old Wives Tale type of product for the most part. IMO, it claimed to do more for you that it would really do. I've used it on upper intakes of worked 22re motors, and some others, but never got real world results out of it.
Until now.
My truck is a 1994 F350, 7.3L PSD, CC, DRW, and I keep my 100gal transfer tank full in the fall/winter for added weight when it snows (its a 2wd). I average around 14mpg in it. Last week, I was in Oreilly's to grab some anti-gel stuff for my diesel. I religiously use Power Service Diesel Kleen additive, but they were out of the white bottles that day. So, I looked at the Seafoam and decided to use it for my old 7.3L Powerstroke as it had some anti-gel properties for the fuel and says its "safe".
****I would not use this in a common rail system as I have no idea if it will hurt it or not****
All I can say is WOW. I track every tank and calculate mileage. My truck has two tanks. Best I have ever gotten out of my rear tank was 220mi, but on my normal commute to/from my shop I get 200mi to a tank. Been this way since I got the truck. I immediately noticed a difference on the rear tank. Getting 240mi out of it this time. And, the front tank is doing the same. I currently sit at 400mi with 1/2 of the front tank still to go.
Plain and simple is that it crushed my normal mileage that I normally get. I bet I am seeing a 2mpg difference if not more. Nothing has changed in my everyday driving either. There hasn't been anymore hwy than street or anything like that with these tanks. So, I know its the Seafoam.
Also, my injectors were rebuilt by Rosewood less than a year ago, so I know they are in good shape as well.
I doubt I will use it for every tank at $7.99/can, but we'll see how things change with my next tank as I will go back to the Power Service again. Maybe it just cleaned out the entire injection system. But, I can honestly say now that the stuff actually works, and works well. Even at $7.99/can, I am saving money with the increased mileage with diesel at $3.69/gallon here in CO.
Scotty
1999.5 F350 DRW, CC, LB, A/T, 7.3L. Bank Exhaust brake, 4" Exhaust, BD power Thruster II turbo, PHP Hydra
AddictedOffroad is offline
post #2 of 11 Old 11-03-2013, 05:34 AM
vandy's Avatar
Ill have to try it out. I've used it in other vehicles but not my truck. I typically get 580ish to a full 2 tanks. My last fill up was just over 600. If this nets me more I may use it on a long trip
vandy is offline
post #3 of 11 Old 11-03-2013, 05:48 AM Thread Starter
I can only dream of mileage like that. My truck is 8500lbs with 4.10s.
You must be skimming every drop out of each tank. 3.55s in your truck?
Scotty
post #4 of 11 Old 11-03-2013, 05:55 AM
vandy's Avatar
Yeah 2wd 3.55 auto. About 285k miles. I've been running her for about 534 days. My avg is 19mpgs. Best was 24 worse was 14.
I run about 50% highway/city. Rarely get over 65
And drive like an.old lady. Tires are transforce with not much tread. If you can't tell I'm a little anal about my fuel economy. So far I've been pretty impressed coming from all my gassers getting 10-15 at best
vandy is offline
post #5 of 11 Old 11-03-2013, 04:41 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Good to know. I have used it in gassers to remove carbon, never thought to use it in diesels
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #6 of 11 Old 11-03-2013, 08:15 PM
Best way is in the tank and directly in the fuel bowl works well too. I always have a can in the garage. Matter of fact today used it in moms tauras because it has been idling and running like crap so I ran it throught the intake. Ooo man it smoked like all hell and now that thing runs and drives like a charm. I get the engine warm and let it soak for like a half hour or so and that seems to work the best. I put it in the oil of my cars a few miles before I do an oil change. I have heard that it is really bad to use in the oil in our trucks. I am not sure of the exact reason, maybe someone can elebarote more?
1997 F250 ,7.3, 4" exhaust, afe cold air, dp tunes, and 33s
viggy924 is offline
post #7 of 11 Old 11-03-2013, 08:33 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 20 Post(s)
I've dumped a healthy dose of Seafoam in my fuel bowl and the rest in the tank on my last filter change. I didn't really notice anything different.
Regarding the Seafoam in oil--from what I've read/heard, since it has alcohol as an ingredient, it is not advisable. It has oil-thinning properties and will wreak havoc on the HPOP and injectors. I'm sure more will chime in.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #8 of 11 Old 11-04-2013, 08:43 AM
I have heard that since seafoam has some alcohol in it, it hurts your lubrication real bad and not to use it on a higher mileage motor because it grabs the crud and sucks it into the injectors. I could easily be dead wrong, but this is just things I've heard or read, also those did not specify what kind of engine, they were just about how it was bad for a diesel engine. I could be dead wrong though, and if I am I will run seafoam in my truck lol
96 7.3 powerstroke, 4.10 gears, 5 speed f350 single cab dually, 3in downpipe from turbo, cat delete and straight piped-SOLD
2001 dodge 2500 2wd auto
7.3kid is offline
post #9 of 11 Old 11-04-2013, 05:04 PM
sethc24's Avatar
Man you guys get awesome mileage. I cant get more than 200 miles out of the front tank and 170 miles from the rear no matter how slow/economical i drive. I may have to try this sea foam.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #10 of 11 Old 11-04-2013, 05:27 PM
I'm a retired Chemist. Been analyzing solvents for use in plastics, paint and adhesives all my life. Want to know what's in "Seafoam"?
Go to a Sherwyn Williams Paint store and get a gallon of VMP Naphtha. Then go to Dudadiesel dot com and order a quart of ANHYDROUS iso propyl alcohol. Mix 95 parts VMP with 5 parts IPA, and there you have it.
Want to verify what I just wrote? Go to the Seafoam web site and find their MSDS, which stands for Material Safety Data Sheet. Google the CAS # and see for yourself.
I have been using the above in all the cars I have ever owned for the past 50 years.
Sometimes I substitute Stoddard Solvent for the VMP when the price is right.
Hope this helps, because for sure you will save big bucks over the cost of Seafoam.
Dick
tartansailor is offline
