1995 innercooler? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-31-2013, 01:03 PM Thread Starter
Quoted: 4 Post(s)
1995 innercooler?
I've been looking at the Banks Innercooler for the 1995, F350, 7.3, E40D. Has anybody put a innercooler in this early model F 350, and what's the difficulty level for doing one yourself? Can it be done with basic tools or is specialty tools needed? Thought I could install it myself if there is no welding or cutting involved. Banks says it usually takes 3 to 4 hours. Me, 2 to 3 days.
timlsalem is offline
post #2 of 5 Old 10-31-2013, 04:03 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Worst part about it is cutting holes in the header panel for the intercooler tubes to go through. Other than that with a kit it should be pretty straight forward. Theres tons of threads on how to do it just search for them and you will find plenty
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 5 Old 11-01-2013, 02:42 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
agreed. one tip install the spyder and then the pipes before cutting your holes that way they don't need to be any bigger than necessary. another tip install the boots on the IC before you install it. they can be a pain to get to if you try and do it the other way.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 5 Old 11-01-2013, 05:50 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Are any of the intercoolers on ebay worth while? I have seen some cross flow with 3" in\out.
dirtcrew51m is offline
post #5 of 5 Old 11-04-2013, 08:55 AM Thread Starter
Quoted: 4 Post(s)
Got looking more closely at my radiator. The innercooler radiator sits in front of the coolant radiator doesn't it? What do you do with the tranny cooler that is sitting on the front of the radiator? Mine measures 12" x 8" x 1". If this has to be moved, where do you move it to so it is still working properly?
