Rough start and idle - Ford Powerstroke Diesel Forum
post #1 of 23 Old 10-30-2013, 09:43 PM Thread Starter
M.F.E.'s Avatar
As it has gotten colder i did glow plugs and UVCH's in my truck and now when it starts it runs really rough. I let it run for a while and if i shut it down and go touch the exhaust manifold where it comes from each cylinder i can tell that it is running comletely on the right left bank but on the right bank it seems to only be running on the front cylinder. sometimes it will pick them up and run nicely and sometimes still at idle it will pick up one or 2 for a second and then drop them back off again. every once in a while maybe 3 times i have noticed my tach not working for a few seconds. up to about 5 seconds and then it will start working again. any thoughts here? its a 95 with 280000 miles.
Sad day to see it leave like that!
M.F.E. is offline
post #2 of 23 Old 10-30-2013, 10:56 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Double check all you UVCH connections plus the ECM connections also.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 23 Old 10-31-2013, 01:15 PM Thread Starter
M.F.E.'s Avatar
If I pull the valve cover to check it think the gasket will still be good? Right away after doing it, it would pick those cylinders up after a minute or 2 and run great but now that its colder not so much. Could it also be CPS?
M.F.E. is offline
post #4 of 23 Old 10-31-2013, 04:44 PM Thread Starter
M.F.E.'s Avatar
Bump, any other ideas or thoughts?
M.F.E. is offline
post #5 of 23 Old 10-31-2013, 07:52 PM
I would check you harness again and if iirc they are reusable just clean and put back my old 5.8 I did that twice (stupid intake plenom). When u are starting the truck does the tach move?
1997 F250 ,7.3, 4" exhaust, afe cold air, dp tunes, and 33s
viggy924 is offline
post #6 of 23 Old 10-31-2013, 08:00 PM Thread Starter
M.F.E.'s Avatar
I will try to start it again tomorrow and see what happens. If so what's the cause.
M.F.E. is offline
post #7 of 23 Old 10-31-2013, 08:14 PM
Well usually if it's not starting and the tact isn't moving while trying to start it's the cps and a bad cps can lead to worse fuel mileage and loss of power but as far as I know you shouldn't have and cylinder firing issues from the cps . I would retrace my steps with the wiring and check over the I injectors with a buzz test. Hope this helps good luck
viggy924 is offline
post #8 of 23 Old 10-31-2013, 10:13 PM Thread Starter
M.F.E.'s Avatar
What is this buzz test?
M.F.E. is offline
post #9 of 23 Old 10-31-2013, 10:15 PM
When you hook up the scan tool and it will cycle through all the injectors and basically u can make sure all 8 injectors are getting the proper voltage and it will make sure the Idm and electrical portions of the injectors are working properly. This is done with the engine off. This does NOT mean the injectors are all perfect in good condition. Remember they are only electronically controlled. The next best this is to do a cylinder contribution test while it's running.
viggy924 is offline
post #10 of 23 Old 11-01-2013, 07:07 AM Thread Starter
M.F.E.'s Avatar
Every time I have tried to find a scan took to use im told there isn't one that the truck is to old and that the only thing I can do it pay to have the $90 diagnostic done on the truck.
M.F.E. is offline
