No FPR Screen - Ford Powerstroke Diesel Forum
post #1 of 14 Old 10-28-2013, 06:44 PM Thread Starter
No FPR Screen
I went to clean my FPR screen this evening and come to find out, mines not there.
I bet it's been off for quite some time, but there's no way to really tell.
What are the downfalls to not running a screen? Funking up the return line?
Sent from AutoGuide.com App
williameub is offline
post #2 of 14 Old 10-28-2013, 07:30 PM
Easier to pick up any big sediment I would assume you run the risk of doing that correct me if I'm wrong someone?
viggy924 is offline
post #3 of 14 Old 10-28-2013, 08:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The screen is after the filter, but what ever the filter misses the missing screen obviously won't catch either
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 14 Old 10-28-2013, 08:28 PM Thread Starter
I'd have to disagree with this. If it is useless, then why do they end up getting caked with crap?
post #5 of 14 Old 10-29-2013, 09:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
in no way did I say it was useless, I said what ever the filter misses the lack of FPR screen will miss it as well, as in what ever trash was going to get caught by the screen is now going through the rest of your injection system
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 14 Old 10-29-2013, 11:39 AM Thread Starter
Ah, thanks. I was reading that first post wrong. My apologies.
I've noticed a lack of power. Could the FPR screen not being there cause this?
What should I check since there isn't a screen?
post #7 of 14 Old 10-29-2013, 11:43 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
not sure a lack of screen would kause a loss in power, but a bad injector because of trash going in will have this effect, but mostly have you checked for boost leaks at the manifolds, up pipes, up pipes gaskets, intake y boots?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 14 Old 10-29-2013, 01:09 PM Thread Starter
I haven't yet. I don't have to tools to do that myself. I'm guessing any competent shop could do a boost leak test for me?
I'll inspect the up-pipes tonight for any noticeable visual signs of a leak.
I have a small fuel leak in the valley. I have a complete rebuild kit for it, and I planned on cleaning the IPR while I was in there.
post #9 of 14 Old 10-29-2013, 06:49 PM
Is there any soot on the firewall or excessive amount any where in the engine bay is one way to check and if u clean the valley really good with degreaser and run the truck you maybe able to pinpoint the fuel leak.
viggy924 is offline
post #10 of 14 Old 10-29-2013, 06:54 PM Thread Starter
I have a small exhaust leak where the downpipe meets the EBPV. No biggie. I haven't checked the up pipe yet.
