a nice clean ! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-27-2013, 10:10 PM Thread Starter
spartan-alteran's Avatar
a nice clean !
hay my engine is starting to get very greesy and yuky has anyone ever actually clean there engine without tarring it apart ? and wat should I cover up I need to clean the top and passenger side of the engine and hint ?
"I think I might have a leak some were so I want to clean it to see if I actually have one "
spartan-alteran is offline
post #2 of 6 Old 10-27-2013, 10:30 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Make sure the engine is completely cool and spray simple green all over the entire engine compartment and let it soak in for 5 min. Then use a pressure washer and spray it down while avoiding the alternator and air filter. IMO everything else is okay, of course don't hold the nozzle on an electrical connector or glow plug relay. I've always downed this with all my Diesel engines and have yet to have a problem. I recommend this to another member and he stated he smelled simple green in the cab after he was done but I haven't ever noticed it.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 6 Old 10-29-2013, 11:37 AM Thread Starter
thank's for the info so the valy 'top' of the engien i can spay it good and clean it all up =D time to find sume simple green and clean it all up il just add a plasitc bag over the air intake and computer and electronics just in case
post #4 of 6 Old 10-29-2013, 11:40 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
be careful with pressurized water at your idm as well, or you will be very sorry
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 6 Old 10-29-2013, 11:53 AM
Black2011SD's Avatar
Dude......I can't even concentrate enough to make sense of what you are saying.
Black2011SD is offline
post #6 of 6 Old 10-29-2013, 12:47 PM
Jweber6.0L's Avatar
Hmm, I was always told by mechanics when I worked at a dealership detailing cars to never drown water under the hood without the engine running. You want the electrical current running as to not saturate components (wiring).
One Method
1. Get the engine moderately warm,not hot (a couple minute run at idle).
2. VERY LIGHTLY saturate the engine with the hose avoiding FICM, alternator, and air filter (they can get a little wet)
3. turn truck off
4. cover the FICM, alternator, and air filter unit (thicker foil was what we used because we could keep reusing it) with whatever you have that is water resistant/proof and will not melt.
5. spray down motor with mean green, simple green, or anything non corrosive. The also make engine bay cleaner which is what we used.
6. wait 15ish mins.
7. turn motor over and immediately start spraying it down while running until satisfied. (you will see steaming, this is good.)
8. then for covered units whipe with a damp washcloth unit satisfied (just water).
9. drive your truck until it is up to full temp then park it, the motor will dry itself.
*Note: Make sure the pressure of the water you are using is not too high. No pressure washing!
Again just one method. Hope this helps.
Jweber6.0L is offline
