OBS intercooler questions - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-27-2013, 03:39 PM Thread Starter
gunmaniac3521's Avatar
good evening all,
I am in the process of acquiring a 6.0 intercooler from a buddy of mine and I am in the process of figuring out the logistics of putting the I/C into the truck. I've done my research and I've read a few of the "how-to'" write-ups and most all of them are saying that I need to get an e99 intake spider. between having a little trouble finding them and wanting to make this as cheap of a project as possible, I am wondering, why cant I just invert the spider I have on my OBS now like this.
If I did this I could cut off the flange to the turbo and weld on a 90 degree exhaust pipe to route towards the I/C and weld an expander onto the spider to connect to the I/C piping.
Has anyone done this before? from what I can see it will work but then again I don't have everything together to mock it up and be for sure. I did move the glow plug relay from its pedestal up to right next to the alternator to get have it clear the I/C piping.
I do for see the I/C piping coming up to the spider possible covering the oil fill hole but that's not a big deal being as that's not used very much and a funnel can easily get around it probably. ill be doing a fuel bowl delete soon to clean up the valley. Just looking for some knowledge on this idea and maybe a "been there, done that" story about it. If anyone has an extra old style spider they're willing to give up cheap in case I jack mine up or if they have a e99 one for real cheap and save me the time of doing this. ( figure id spend 50 on pipe just to set the spider)
gunmaniac3521 is offline
post #2 of 10 Old 10-27-2013, 03:45 PM
erics diesel's Avatar
I did what you're talking about and it works fine got the idea from another forum I'll post a link when I get to my computer verses my phone
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 10 Old 10-27-2013, 05:04 PM
heres the link
6.0L intercooler install in '92-'96 body
and heres a pic of mine I used one factory pipe from a sd and made the rest out of stainless steel rather than exhaust pipe
post #4 of 10 Old 10-28-2013, 03:39 PM Thread Starter
sweet, thanks for the help.
post #5 of 10 Old 10-28-2013, 03:45 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
There is a guy with an e99 spyder for sale for 150 in the classifieds section
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #6 of 10 Old 10-28-2013, 07:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
There was a great write up on fourdoorbronco.com a guy cut the stock y pipe and used exhaust pipe to make the rest
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 10 Old 12-14-2014, 06:12 PM
I was thinking about this very same thing just the other day, did this ever get done?
BTW an extended oil fill neck is available from ford $7 can't beat that.
djs96 is offline
post #8 of 10 Old 12-14-2014, 06:53 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It's the factory one from the sd which comes intercooled
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 10 Old 12-15-2014, 04:41 AM Thread Starter
I didn't do it but erics diesel did, he has pics further up the thread. I ended up getting an e99 spyder and doing it that way. I didn't want any steel pipe there that would rust so I used all aluminum.
post #10 of 10 Old 12-15-2014, 10:34 AM
thanks guys
djs96 is offline
