ecu interchgangability - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-27-2013, 10:11 AM Thread Starter
97dieselstroke's Avatar
My truck is throwing a p0605 code internal control modual rom error. thats telling me that my ecu is dead. i did all the other tests to diagnose a no start all checked out good. hooked up my mt2500 did a koeo test and the p0605 came up. I guess my question is that a friend has a ecu from a 97 5spd # on the ecu are f5tf-12a60-fg the # on my ecu 95 5spd is f7tf-12a650-sb will they interchange? As long as they are both manual trans and fef emmissions they should be the same? thanks for any input Derek
97 f350 cclb 4wd xlt 7.3 e4od 34x12.5 Bfg allterrains 3" diamondeye s/s downpipe to 4" to 5" dual black turnout stacks, aux trans cooler, trans temp guage,diy 6637 intake, ts 6 pos chip. fpr shim, tc lockup switch, 10k mod
95F350 CCLB xlt 7.3 zf5 4wd 4" lift 35" procomp extreme all terrains 3" diamond eyes dp 4" straight ex. diy 6637
97 f250 eclb xlt 7.3 e4od 4wd bone stock
97dieselstroke is offline
post #2 of 2 Old 10-28-2013, 05:36 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
If they are both manual trans and federal emissions trucks, yes they should interchange. Cheers!
Patrick Feeley is offline
