1997 7.3 Rear Leaf Spring Hanger - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-27-2013, 08:50 AM Thread Starter
Driving down the road and .... POP. Leaf spring hanger let go after 138,000 miles.
Found one in stock at a local parts store so i'm going to go grab it because the truck is my daily driver. My only question is how the hell do i remove the thing?
I read that it's pop riveted in. I do have an older MAC air hammer that i could use to attempt to chiesel it out. Then you just drop grade 8 bolts in.
Am i missing anything? Any tips? I have a car lift (need to check capacity of it first), a forklift rated for ~6,000 pounds, an air hammer, a good compressor, and a good impact gun. Just need to figure out the procedure for fixing this.
Does anyone know a 1997 7.3 extended cab 8' bed curb weight?
HudsonN is offline
post #2 of 8 Old 10-27-2013, 10:04 AM
Chop's Avatar
Take a cut off wheel and grind off the rivets and then punch out the remainder with air hammer or punches .
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #3 of 8 Old 10-27-2013, 11:38 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
6000 lbs is really close too close. The 8000 lb lift at the one dealer I worked at was pissed whenever it saw anything near 3/4 ton
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #4 of 8 Old 10-27-2013, 01:20 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
curb weight i would ~ 7200-7400 with nothing in the bed/cab
grinding wheel and drive the rivet out.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 8 Old 10-27-2013, 02:20 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
I used my engine hoist to lift from the trailer hitch, enough to take the weight off the springs.
dirtcrew51m is offline
post #6 of 8 Old 10-27-2013, 05:59 PM
Use that forklift to lift the back of the truck up enough.
Sent from AutoGuide.com App
williameub is offline
post #7 of 8 Old 10-28-2013, 04:06 AM
Quoted: 58 Post(s)
The new shackle/hanger should come with bolts/nuts.
Check the fixed hangers at the front of the springs, as they're also rust-prone.
madpogue is offline
post #8 of 8 Old 10-28-2013, 02:04 PM
Quoted: 6 Post(s)
While you are at it, check your upper shock mounts, one of mine was completely broke, and the other barely hanging on.
