96 F-350 Power problems - Ford Powerstroke Diesel Forum
Old 12-20-2005, 02:40 AM
I have a good one for all of you. Please e-mail any suggestions. I have a 96 f-350, with a 7.3 powerstroke. It has 215,000, oil has been changed every 3000 since I had it. Now while driving at top speeds, passing gear... my truck shutters and almost dies. Once I pull off and cut it off, it starts right up with a miminal miss. It only does this if I put my foot in her. I took a sample of fuel from the filter housing, no water or clouds are in it. Fuel filter was replaced, and now I am at a lose. No check engine lights, water, or fuel filter lights come on. Has anyone ran into this before???? Please help me with some thoughts.
V. Johnson
Old 01-12-2006, 09:12 PM
V. Johnson
COULD BE YOUR LIFT PUMP IS GETTING WEAK. AND NOT SUPPLYING FUEL UNDER A HEAVY LOAD. YOU CAN TAP A GAUGE INTO IT AND SEE WHAT IT SAYS AS YOU DRIVE. SHOULD NOT DROP AT FULL LOAD BELOW ABOUT 3-4 LBS. PSI.
