Rear main or oil pan?? What's more common to leak? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-24-2013, 08:51 PM Thread Starter
So I have a pretty good drip coming from the back of the block before I remove the inspection cover , just wanted to ask ... What's more common to leak?
Oil pan gasket or rear main?
Some Drunk Guy is offline
post #2 of 4 Old 10-25-2013, 07:20 AM
Check for a leak in the valley. Leaks there will run down the back of the block.
The EVPV on the turbo pedestal is a common place for a leak.
Sent from AutoGuide.com App
williameub is offline
post #3 of 4 Old 10-25-2013, 07:30 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Like was said. Check the valley and back of heads. The rear main almost never leaks on these.
The pan uses SPECIAL RTV to seal it, not a gasket
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 4 Old 10-25-2013, 08:41 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Or the inspection cover has worn a hole in the back of the sump....
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
