Signs of dualmass going bad? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-24-2013, 03:03 PM Thread Starter
Halby95's Avatar
Hi, so i changed the ujoints out on my truck thinking it was them that was squeaking but its still doing it. I got under the truck and could hear a kind of squeaking coming from the transmission. By the way its a zf5. It seems like their is more vibration than normal on the highway as well. Could this be a sign of the dmf going bad? Thanks you for any and all help.
1996 F250
Reg. Cab
5 inch exhaust
Afe Proguard 7 intake
Tony Wildman chip
4 inch lift with 295/70R18 Trail Grapplers
Vortex Bedliner on rockers
Halby95 is offline
post #2 of 18 Old 10-24-2013, 03:33 PM
Quoted: 53 Post(s)
Most critical sign:
Q: Is it a dual-mass flywheel?
A: If yes, it's going bad.
Okay, more specifically:
- You hear a little extra clatter on engine shutdown
- That vibration you mention - if it goes away when you put the clutch in and coast
- You remove the inspection cover, and can move the flywheel several degrees
- You remove the inspection cover and any little bits of whatever fall out
madpogue is offline
post #3 of 18 Old 10-24-2013, 03:50 PM Thread Starter
Halby95's Avatar
There could be some extra clatter at shutdown ive kinda noticed that every once in awhile. I guess i havent really tried pushing the clutch in at highway speeds. However the squeakin noise that i hear happens with the clutch in or out. It usually squeaks at about 35-40 and 5-10mph. I havent removed the inspection cover. Kinda noob question but if i remove that will all my fluid drain out?
1996 F250
Reg. Cab
5 inch exhaust
Tony Wildman chip
Halby95 is offline
post #4 of 18 Old 10-24-2013, 04:22 PM
Quoted: 53 Post(s)
No, the inspection cover opens access to the "bellhousing" area _between_ the engine and tranny. So it's "outside" of both; nothing will drain out.
madpogue is offline
post #5 of 18 Old 10-24-2013, 04:45 PM Thread Starter
Halby95's Avatar
Ok good deal. I will look into taking that off tommorow. I apreciate the help.
1996 F250
Reg. Cab
5 inch exhaust
Tony Wildman chip
Halby95 is offline
post #6 of 18 Old 10-24-2013, 04:56 PM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
could it be a DP rubbing?
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 18 Old 10-24-2013, 05:33 PM Thread Starter
Halby95's Avatar
No i dont think it is but i will check that tommorow as well.
1996 F250
Reg. Cab
5 inch exhaust
Tony Wildman chip
Halby95 is offline
post #8 of 18 Old 10-25-2013, 05:30 AM
95Hailey7.3's Avatar
Quoted: 4 Post(s)
When I noticed my DMF gooing bad, it was a very distinct chatter, clanking and vibration. To me it almost seemed as if the motor wasn't running on all cylinders.
The noise comes and goes right, usually at start up, when in neutral, and hard shut down.
Like Madpogue stated remove the cover, use a big flat blade screw driver and if both flywheels move easily. Move them back and forth fast and see if the noise sounds similar. If it moves that's most likely your problem if and when the clutch its pressed in it stops it's dam there your problem.
If that it's the problem you can do the DMF to SMF swap. Others can chime in on the brands you can use. I choose the Autozone SMF flywheel and clutch components. Been doing very well. Any questions on how it's performing ask away.
I'll see if I have a video of when it was acting up. So you can compare it to your noise.
1972 Ford F100 5.9L FE Sport Custom Single Cab Long Bed 4x4 6" Rancho lift kit, 16x10 Pacer rims wrapped in Durango 315 75 R16.
1995 Ford F-250 XLT 7.3L PSD Super Cab Long Bed, everything stock, rims wrapped in Rocky Mountain Faulkens.
1994 Ford F-350 XLT 7.3L PSD Centurion Super Crew Cab Long Bed dual rear wheel, Alcoa Rims wrapped in Transforce H/T & Big Foot A/T
Young Gun, Proudly Serving So My Family and Friends can LIVE IN FREEDOM.
95Hailey7.3 is offline
post #9 of 18 Old 10-25-2013, 12:04 PM Thread Starter
Halby95's Avatar
Well i removed the cover and i couldnt move anything and there werent any pieces in the cover. Everything looked good. I checked the downpipe and it was close but i looked at with the truck running through all the rpns and couldnt get it to replicate the noise. So now im looking at the front brakes. Is there anyway to tell if the calipers sre stick without removing or do i have to remove them. Im kind of out of ideas as to what it could be.
1996 F250
Reg. Cab
5 inch exhaust
Tony Wildman chip
Halby95 is offline
post #10 of 18 Old 10-25-2013, 04:28 PM
A bad t/o bearing will squeal.
Sent from AutoGuide.com App
williameub is offline
