Front cover 95 & 97 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-23-2013, 06:15 AM Thread Starter
Front cover 95 & 97
One question, the front cover on the 95 engine I have is different than the one I have on the 97 .So can I use the HPOP on the 97 to go on the 95.Or would I need to change the front cover on the 95.
handydo is offline
post #2 of 3 Old 10-23-2013, 08:40 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
Different covers and the HPOP cannot be swapped between them. The front of the engine (not the cover) is the same all the way up to the '03 SD. Upping the '95 to a '96-'03 cover will allow you more flexibility and cheaper more available pumps.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 3 Old 10-23-2013, 05:59 PM Thread Starter
re:front cover
I guess I should have ask this before I sealed the 95 up ,oh well I guess I will take it apart again and do the 97 one, Live and learn ,Thanks for the reply
handydo is offline
