chirping belt - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-23-2013, 06:37 AM Thread Starter
chirping belt
my last belt I put on over 2 years ago and it started squeeling so I replaced it. squeeling went away for a couple weeks. now I'm getting a chirping sounds when the printed label hits one pulley. if I wet the belt slightly it goes away so I know it's the belt. any tricks to keep it quiet?
tony0713 is offline
post #2 of 17 Old 10-23-2013, 08:31 AM
dazed01's Avatar
I usually use a wire brush to clean the belt off. If that doesn't work, try exchanging it for a different brand belt?
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #3 of 17 Old 10-23-2013, 08:47 AM Thread Starter
I tried that on this belt and the last.
tony0713 is offline
post #4 of 17 Old 10-23-2013, 08:51 AM
dazed01's Avatar
Miss-aligned pulley? Have you checked it out with a stethoscope to find the exact location the chirp is coming from? Is one of the pulleys dirty?
dazed01 is offline
post #5 of 17 Old 10-23-2013, 08:54 AM
Heavy_GD's Avatar
Quoted: 1329 Post(s)
Feedback Score: 3 reviews
I've found that chirps are bad waterpumps on gas motors... if there is no rust on the pulleys, the tensioner is good, then you may be losing a bearing on a pulley.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #6 of 17 Old 10-23-2013, 08:56 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
May not be your issue but I had this with belts sometimes and usually find that taking the belt off and reversing it helped. There is a point in the belt where they join them end to end and it's not always a straight bond. The belt is not allowed to wander in the grooves of the driven accessories but is allowed to wander on the idler pulleys. This sometimes causes a squeak. Of course in the old days when a belt was squeaking and someone was complaining about it we started the engine and laid a piece of hard hand soap on both sides of the belt and this usually made the squeak go away. By the time the soap wore off the belt was broken in and didn't squeak anymore anyway.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #7 of 17 Old 10-23-2013, 09:24 AM
Heavy_GD's Avatar
haha, the hand soap trick is old school!
GD
post #8 of 17 Old 10-23-2013, 09:42 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
But it works.
....are those Lambo doors on a SD???
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 17 Old 10-23-2013, 09:52 AM
Heavy_GD's Avatar
its even cooler because the rear doors are suicide... its a show truck not a work truck.
GD
post #10 of 17 Old 10-23-2013, 10:17 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Never seen that before on a SD. Do they pop out and then up? Or do they swing diagonally? From the pic it looks like its harder to get into the truck, is it?
Matt
'97
-Stage II trans.
BigFuel is offline
