Noob question #3 EGT's... - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-22-2013, 11:02 PM Thread Starter
So how many people have ran their EGT'S up either driving hard or towing uphill? I guess the real noob question I have is what happens when the temps are high and how Long do you have before something breaks?? any experiences??
Some Drunk Guy is offline
post #2 of 10 Old 10-23-2013, 12:40 AM
BIG Laing's Avatar
Keep it below 1350 F and you should be fine. Some people say short spurts of 1500 F are fine.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 10 Old 10-23-2013, 05:33 AM Thread Starter
So what is first to break when the temps get too high? Turbo?
post #4 of 10 Old 10-23-2013, 06:14 AM
ArXane's Avatar
From what I have seen, yes. Bearings/seals in the turbo. But really not good for anything.
2000 F250 Lariat, CC, Long Bed PSD, 4x4, Manual, 102K Miles 4.30 gears, Truspeed
Performance Mods: Tuned by PHP, Wicked Wheel, Gauges, AIH Delete, 5" straight exhaust, DIY Intake
Suspension: 8" Fabtech all spring lift, Fabtech Dual Front shock mounts, Fabtech Dual steering stabilizer, 17" ATX Vice, 37" Toyo M/T
1995 RC F350 Longbed 4x4, Manual, 310K miles, Downpipe, cat delete, FPR shim. (Farm Truck)
ArXane is offline
post #5 of 10 Old 10-23-2013, 08:49 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 49 Post(s)
By the time your gauge sender sees it your cylinder temps are already above that temp. Unloaded I have a real hard time getting to 1200*. Towing I can easily get to 1300* but will not personally run above 1250*. It's not only the turbo that goes but your pistons are an Aluminum Alloy. Melted and/or cracked pistons are the worry after the turbo is getting damaged. The sender needs to be as close to the cylinder as possible. Most of us don't pull our motors for the probe install so we put it in the driver side bend right before the up-pipe. Senders post turbo should never be allowed to exceed 1000*.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 10 Old 10-23-2013, 10:56 AM Thread Starter
Wow that's crazy!
post #7 of 10 Old 10-23-2013, 01:17 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
matt show him the one with the two different probes.
also beware that what the gauge reads maybe be off by as much as 100* depending on the quality of the gauge
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 10 Old 10-23-2013, 02:22 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 49 Post(s)
12 physical inches apart (less than the length of the up-pipe between the port manifold and turbo manifold/collector), maybe 18-20 inches apart as the exhaust flows through the turbo:
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #9 of 10 Old 10-23-2013, 02:34 PM
01Crewcab7.3's Avatar
Wow that's insane.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #10 of 10 Old 10-23-2013, 02:38 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 49 Post(s)
Turbos doing its' job by eating all the heat it can take but you'd never know it with just a single post-turbo sender. I can heat my lunch while the students are performing their tests.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
