Noob question#2 must do upgrades? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-22-2013, 08:47 PM Thread Starter
Ok so after reading performance posts I have to ask..
What was the best performance mod you did to your 7.3?
What is a must do upgrade?
Air intake?
Inter cooler?
Down pipe?
Some Drunk Guy is offline
post #2 of 8 Old 10-22-2013, 09:03 PM
01Crewcab7.3's Avatar
DIY intake
3" downpipe
4" straight pipe
Gauges
Custom chip
Built Trans
Efuel
Intercooler
Injectors
Turbo
Hpop
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 8 Old 10-22-2013, 09:12 PM Thread Starter
Is that the order you did your upgrades or just a suggestion?
Do you have any write ups or pictures of your DIY intake or inter cooler? Thanks in advance
post #4 of 8 Old 10-22-2013, 09:14 PM Thread Starter
Oh and another noob question... Why does everyone suggest gauges? Like pillar gauges s that what every one means to look at the read outs?
post #5 of 8 Old 10-22-2013, 09:19 PM
Pyrometer, boost, Trans temp.
Tim
post #6 of 8 Old 10-23-2013, 06:12 AM
ArXane's Avatar
Everyone suggest gauges because they are the only way to monitor what your engine/tranny are doing. Back when I had an auto, I would of burnt it up if I didn't have a tranny gauge to keep it from getting to hot. I was able to keep an eye on it and either pull over or hold back on the throttle depending on the temp.
Pyro will keep you from toasting your turbo and I feel a boost gauge will let me know when I start having a problem with something or if a mod I did gives me any more power/boost.
2000 F250 Lariat, CC, Long Bed PSD, 4x4, Manual, 102K Miles 4.30 gears, Truspeed
Performance Mods: Tuned by PHP, Wicked Wheel, Gauges, AIH Delete, 5" straight exhaust, DIY Intake
Suspension: 8" Fabtech all spring lift, Fabtech Dual Front shock mounts, Fabtech Dual steering stabilizer, 17" ATX Vice, 37" Toyo M/T
1995 RC F350 Longbed 4x4, Manual, 310K miles, Downpipe, cat delete, FPR shim. (Farm Truck)
ArXane is offline
post #7 of 8 Old 10-23-2013, 07:09 AM Thread Starter
Ah thanks for the info, makes sense!
post #8 of 8 Old 10-23-2013, 08:35 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
Originally Posted by 01Crewcab7.3 View Post
DIY intake
3" downpipe
4" straight pipe
Gauges
Custom chip
Built Trans
Efuel
Intercooler
Injectors
Turbo
Hpop
I did First Second Third
I cheated with the HPOP as I had a strong HPOP that was before the injector swap pushing Cali injectors
Agreed
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
