New guy with questions - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-22-2013, 07:51 PM Thread Starter
TheBeast7.3's Avatar
Im a newbie, I bought my truck in June and have slowly been working on it. I have some questions!I have been searching around for a rear window switch for my crew cab and can not find any Does anyone out there know where I could find one? Im also looking for a good resonable chip. Are the ts 6 position any good? Whats the best turbo up grade? or should I do injectors? Thanks guys
95 F-350 crew cab 4x4
Downpipe, Napa Filter, Stock exhaust delete
, 10k mod, gauges, Raceline Renegade wrapped in 285/75 16 toyo
Case IH Mechanic
TheBeast7.3 is offline
post #2 of 4 Old 10-23-2013, 10:14 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
The Driver door switch at operates the rear windows? Dorman makes a reproduction switch (Dorman #49235) that you can get/order from any autoparts store. I find that most of the time that I think the switch is bad that it is usually the connector to the switch that has oxidized. just removing the connector and cleaning the contact area makes it work again.
Tunes are a personal thing. Most all of them are sold based on the TS style chip reburned to the sellers tunes. I have Beans Diesel tunes and Tony Wildman tunes. Others like Gearhead, DP Tuners, and PHP tunes. That is something you will have to experience and test for yourself.
The only real drop in turbo for the OBS is Beans Diesel D66 turbo. This is a modified turbo from the factory metal. Others are selling a very similar turbo. Other then that you are looking at either a Modded H2e or a T4 mounted turbo similar to a Cummins turbo. There a lot of turbos that you could use after converting your exhaust system to a T4 mount but this is an expensive swap. Some of us would say that the turbo is not a worthy upgrade till you are at 160/100 injectors anyway. The factory turbo can take you a long way (some have use the factory turbo with 250/200 injectors).
Injectors like tunes are a personal thing. You need to first establish a personal goal for you and your truck. Then call Cary@CP_Performance, Beans Diesel, Swamps, Justin@DP Tuner, and PHP (and others in the Sponsor section of the .ORG). All are very helpful and will tell you their personal feeling toward what you want to do. Have a lot of time to talk as there is a lot of good sponsor information out there, you just need to listen and ask more questions.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 4 Old 10-26-2013, 04:30 PM Thread Starter
Its the switch in the rear door the two halves of the switch fell apart. Im looking for a replacement. And Im just looking for some easy power upgrades. Thank you
Case IH Mechanic
post #4 of 4 Old 10-26-2013, 10:18 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Ah, so a single up/down switch. DORMAN Part # 901306
Pick-and-pull time: 6.0 oil cooler if you are an Auto. Also if you have an Auto look for a SD 7.3 4r100 trans pan and a '05+ rear axle pan. They have drain plugs. Inter cooler out of either a SD 7.3 or a 6.0. You can use the SD 7.3 pipes but you'll need a E99 spyder and to lengthen the cold pipe a couple inches at the spyder. Look for metal end caps, not plastic. 1.0 turbine housing.
Careful with that 10k mod, it does not play fair with others.
Matt
'97
-Stage II trans.
BigFuel is offline
